Page 1 of 11 123 ... LastLast
Results 1 to 10 of 105
Thread: Playing with an Audi SQ5 TDI
    Playing with an Audi SQ5 TDI bi-turbo
    Heya - decided to start a new thread as the other one was a bit of a mess.
    In August 2018 I purchased a 2015 model Audi SQ5 for the wife to drive around and to be our primary family car. Needed something with some boot space and practical so we can fit our young child as well as large-ish dog etc. But apart from practicality, both the wife and I are car enthusiasts and love having powerful cars.
    This is the 230kw / 650nm model with the 3.0TDI V6 biturbo and 8 speed ZF auto. My brother who worked at the local Lexus dealership at the time sourced it for us, it has just turned 3 yrs old, 1 owner and had done 29,000km (I assume it was a lease car) and came from Melbourne.
    The car was very well spec'd, with only the black grill/window trim being the only desirable option not on the car - but it had the much more attractive quilted leather seats, 21" rims, Bang & Olufsen stereo (which pumps), carbon interior trim, heated seats, radar cruise and panoramic sunroof. The RRP on this car new with the options fitted would have been approx $113k, we paid $66k.
    The car was due for its 3rd service, so was swiftly booked into Pete @ Newcastle VW Centre for the service.
    Shortly after the service, we got a recall letter from Audi to replace the heater coil unit, so that was done too.
    Things that might interest you:
    • Stage 1 tune from Underground Performance
    • K&N replacement air filter
    • Spulen SQ5 flush spacer kit (15mm F and 20mm R)
    • Flashlube Catch Can Pro
    • 034 Motorsports rear diff carrier inserts
    • 034 Motorsports diff carrier inserts
    • 034 Motorsports rear swaybar and Moog endlinks
    • Akebono Euro Ceramic brake pads
    2017 Ford Fiesta ST
    6 months later...........
    Gave the old girl an oil change. It was serviced about 7 months ago/8,000kms ago (by Pete @ Newcastle VW Centre) but I always like doing 6 month oil changes so I figure ill do one myself in between each "log book" service.
    I enjoy doing the oil changes myself, and it gives me a chance to study the engine/driveline and inspect for any issues/leaks/worn items. The sump, swaybar, subframe and undertray were a bit grotty (presumably from previous sloppy oil changes as there are no leaks) so I gave everything a good degrease and clean while I was in there.
    The cabin filter was dirty and had been starting to smell a bit the past month or two so in went a new one.
    It was the first time I had done an oil change on this car so I was pleasantly surprised to see that its an easy car to work on which was both welcomed and surprising.
    Also changed the brake pads all round to Bremtec Euroline Ceramic which are less dusty than the stock pads but still too dusty for my liking, so will source some ATE Ceramic or Akebono Euro Ceramic pads in the near future.
    2017 Ford Fiesta ST
    Bought a Catch Can for the old girl recently. I went straight into looking at the Provent due to its popularity but its quite large (lengthwise) and i couldnt find a suitable area in the busy engine bay to be able to fit it. Ended up finding the Catch Can Pro which is also German made with similar specs to the Provent, but a little smaller in overall size and i have made a mounting bracket to secure it behind the passenger side headlight.
    Catch Can Pro - Genuine Flashlube
    The RRP is around the $280-300 mark but I got it via a special order from Supercheap Auto when they had a sale recently for just over $200. Its German made, nicely designed and has the 19mm inlet and outlet same as the Provent.
    There are no kits (i have Googled extensively) to suit the 3.0TDI bi-turbo which I found weird considering this engine is quite popular and used in various Audi/Porsche models, so I have purchased some 19mm oil hose and various fittings etc to be able to mount it onto the car. Only one of the cam covers has the breather/PCV mechanism with that accordion hose feeds back into the intake just before the primary turbo - so this is where i will be tapping in and letting the catch can clean the air.
    Who doesnt like a OEM billet compressor wheel? You can see the spot where the PCV plumbs back in just before the turbo.
    1st turbo up top, 2nd turbo hiding down below.
    Tapping into the factory PCV accordion hose that goes between the valve cover and the turbo inlet pipe. I used the fittings but cut the hard plastic hose off.
    Catch can location (had to make a custom bracket to mount it securely).
    End result. I need to get half a dozen hose clamps which i will get this weekend but for now every connection has a zip tie holding everything together.
    2017 Ford Fiesta ST
    It wasn't long before I was looking at remap's for the SQ5 (not that it really needed any more power, but why not). After considering the options below and speaking to all of the companies, I decided to go with Underground Performance because i know Alex and also the remote tune option was attractive to me. He also agreed to try and turn off the EGR for me (which didn't work in the end).
    The tunes all all quite similar in that they quote approx+25-30kw and +90-100nm.
    - Superchips (on sale, very cheap - tune via hand controller)
    - Celtic Tuning (via Zadtec Performance in Sydney). Remote tune or visit workshop in Sydney.
    - Tarmac Engineering (tune via hand controller)
    - Underground Performance (remote tune)
    - Tunes that Transporter sells through MRL Automotive (unfortunately he cannot tune remotely, and seeing I am in NSW and he is in SA this option is not realistic)
    Long story short, the car is finally tuned and running well, but boy oh boy was it an effort. The remote tuning process didn't work (tried several times on different days). Drove to what seemed like the end of the world (Ingleburn, Sydney - a fair drive from Newcastle) to have the tune done by Underground Performance dealer, Pacortech. This process took about 3 hours and then i left with what I was told was a stage 1 tune and EGR delete.
    Drove home, everything seemed fine, then about a week later I decided to check my VAGDPF app which I use to keep an eye on the car's DPF and it's regen's - and the app is telling me that the DPF hasnt done a burn in 800km. Hmmm this is odd im thinking as this car religiously done a DPF regen every 500-600km. This carried on for a good 4-6 weeks with the car not doing a DPF regen (and yes i contacted Underground about it - was told its fine but i knew something was wrong). Then a few weeks later ive got warning lights on the dash, and reduced performance. And a week or so after that im in limp mode with about 5kw. All this in the week before Christmas - so right when you need the car and right when Underground closes for Xmas.
    Thankfully Alex from Underground sent me a CMD Flash tool which (along with software) allowed me to put the car back to its stock map - which then told me that the DPF was 588% full (yikes). I had to physically remove the 2x DPF's off the car and flush it out with my Gerni, then reset the DPF using VCDS which THANKFULLY put the car back to normal.
    After a good 8-10 days of driving around successfully with the stock map on the car, I was able to flash it to a normal stage 1 tune (no EGR delete) and the car has been running fine since.
    Turns out the original remap put on the car messed up the DPF signals so the car thought the DPF was not full, but in actual fact it was completely blocked.
    All in all - a car that was already fairly quick is now quicker. My best 0-100kph before the tune was 5.6 seconds and after the tune i can get between 5.0 and 5.1 for the 0-100kph dash.
    2017 Ford Fiesta ST
    I have been looking into tightening up the "driveline slop" this car has, in particular the rough gear change from 1st to 2nd which I believe is caused by soft transmission and rear diff mounts which are full of voids that allow a lot of movement. There is also some feedback movement from the driveline on deceleration from 3rd to 2nd. All the SQ5's we test drove did a similar thing so it's not a problem with our car as such, just the way they are designed.
    I purchased a 034 Motorsports transmission mount and rear diff carrier mounts. I believe it will be the rear diff carrier mounts that will make the biggest difference, but will report back once the parts arrive and i can install them and test the difference.
    034Motorsports rear differential cradle inserts were installed and they have made a considerable difference in reducing the drive line "slop" that these cars have from factory. Very happy with this little mod, and best of all it was a super easy and quick install and totally reversible. Anyone with a B8 series A4/S4/A5/S5//Q5/SQ5 etc should install these.
    Also recently purchased and installed some Spulen (15mm front and 20mm rear) wheel spacers and new bolts from USP Motorsports which give the car a much nicer stance on the road and push the wheels out. SPULEN Audi Q5/SQ5 Flush Kit - WSKT-Q5F - 6928
    2017 Ford Fiesta ST
    P2006 Intake manifold runner control stuck closed bank 1.
    Upon Googling, i can see this type of error is pretty common on the single turbo 3.0T V6 TDI engine in the normal Q5/A6 etc, but have not been able to find any information relating to the bi-turbo engine used in the SQ5 (and several other Audi models such as the A6). The inlet manifold design is also different on these 2 engines.
    I cleared the error code to see if it was a one-off or if it would come back again, and it came back again the following day.
    So I decided to pull off some intake bits and see what i was dealing with - to my surprise the intake pipe, throttle plate assembly and intake manifold (all located after where the EGR is plumbed into the intake) had a thick layer of soot/carbon junk on them....no wonder I was getting the error!!!
    I knew this was an issue with modern diesel engines and emissions targets but wasn't aware it would be this bad with only 35,000km.
    Anyway, with a combination of petrol, degreaser spray and a soft wire brush these parts are looking much cleaner and the error has not re-appeared.....yet.
    I have since purchased a can of Liqui-Moly diesel intake cleaner which i will run through the engine sometime this week. I am also going to look into the possibility of an EGR delete (either physical or ECU coded delete) to stop this from happening again.
    UPDATE Jan 2024: After doing this intake clean several more times over the past few years, the best product I have found is regular carby cleaner like this Pro-Strength Throttle Body & Carby Cleaner (CARB400) All the other products (petrol/degreaser/Liqui Moly intake decarb etc) do basically nothing to break down the carbon. The carby cleaner is quite effective though.
    Before:
    After (not perfect but much better). I also cleaned the plastic pipe leading to the inlet manifold and scrapped out the inlet manifold as best i could but didn't take pics as my hands were pretty grotty by then:
    2017 Ford Fiesta ST
    Got some new tyres on the SQ5 a few weeks ago (Kumho Crugen HP91 255/40/R21) which replaced the extremely expensive and fast wearing factory Pirelli PZero's. The Kumho's look much better on the rims, have a higher treadwear number 420 vs 280) and should last longer due to being less of a high performance oriented tyre which is pretty unnecessary for this vehicle and they type of driving we do. So far steering feel with the new tyres is more direct and there is no difference in terms of road noise etc.
    Given the rare-ish tyre size, there are only a few tyres to choose from, with Winrun being the cheapest, then Kumho and Dunlop being around the $400 each mark, and then up over $500 each for Continental, Michelin and Pirelli. After having nearly $4k in unexpected vet bills in the past 6 weeks i didn't fancy paying $2k for a set of tyres, so I did some research on the Kumho's and they rated well - so I chose to give them a go. Actually got the Kumho's on special for $335 each so very impressed with them so far for the money.
    Kumho Crugen HP91 - Tyre Tests and Reviews @ Tyre Reviews
    Also took the opportunity to install the 034Motorsports diff mount insert which i purchased recently to complete the drivetrain stiffening - now having the gearbox mount insert, diff carriers inserts, and now the diff mount insert. The SQ5 had quite a lot of drivetrain slop from the factory, so these inserts have helped to reduce this.
    2017 Ford Fiesta ST
    Sep 2016
    Nice purchase Playing with an Audi SQ5 TDI
    The sq5 seem a capable all rounder, How does it handle and drive compared to a golf (I assume you have based on user name lol)
    Any more plans for the car?
    Sent from my SM-G977B using Tapatalk
    Quote Originally Posted by adey88 View Post
    Yes I used to have a Mk6 R and a Mk6 GTI which were both pretty modified. The SQ5 is a pretty heavy car so its very different to drive compared to the nimble Golf's. And with the SQ5 being turbo diesel you drive it riding the wave of torque between 1,500-4,000rpm rather than revving the hell out of it so to speak. It revs to about 5,000rpm but there is really no point revving it this high as peak power and torque are around 3,500-4,000rpm.
    But it handles reasonably well for a big heavy car, brakes are excellent, had oodles of torque (about 750nm now that its tuned) and the gearbox is smooth (when moving) and really quick to shift. At slow speeds I do not like the gearbox as its a bit jerky from takeoff and from 1st > 2nd gear, but once you are moving its much better.
    As for future plans, I have a few things I will likely tackle over the next 12 months, but as this is my wife's car it wont be anything too crazy:
    - Intercooler upgrade
    - Basic water injection setup to help keep carbon buildup down
    - 034 Motorsports rear swaybar upgrade
    Link to my Mk6 R and Mk6 GTI threads are here if you are interested.
    Golf R and Golf GTI
    2017 Ford Fiesta ST
    Mar 2011
    Sunshine Coast
    Wow! Impressive. Thank you for sharing,very informative.
