Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 120
Thread: My Mk7 GTI PP....turns out I cant resist the VAG.
  1. #51
    Mar 2009
    Surely VW will cover if it's out of warranty by a couple of months.
    Sent from my SM-G965F using Tapatalk
    MY07 Red GTI 3 Door
  2. #52
    Nov 2007
    Quote Originally Posted by Johnbu View Post
    They should yes, but this is apparently another VW part that will fail on you many times over what is a reasonable life expectancy of the vehicle. They may cover 1, maybe even 2 but that only gets me to maybe 60,000km, what do I do for the rest of the expected 120,000km it will be with us? Pay $1200+ each time then? Rather find a quality replacement that will last for 100,000km ...
    Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP (mods are underway ) 2018 MY18 Golf 110TSI Trendline manual White (with mods now 150TSI) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 10 Previous VWs and some others ...
  3. #53
    May 2015
    Really interested in this aftermarket waterpump .... our TSI (same pump I've been told) at 3years and 2 months and 26K kms now have a leaking housing Its 2 months out of warranty so I will make some noise at VW but am very tempted to just fit a decent metal aftermarket part instead. Where did you hear about this?
    Sorry Lucas for the thread hijack.
    My specialist VW mechanic showed me a photo of the water pump, but I can’t recall where it came from - an overseas trade supplier, I think? It wasn’t for sale online.
    I’ve seen the Mk 6 aluminium pumps online and I guess it is only a matter of time before there will be one for the Mk 7. I’m sure there will be plenty of demand....
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
  4. #54
    After a 6 week or thereabouts wait, my CTS catback arrived on Monday morning just before I had to go to work. So I bailed from work a bit early on Monday afternoon and got the car up in the air and started work.
    The exhaust was well packaged with all the mufflers bubble wrapped and then all pipes wrapped in a thick see through plastic to prevent rubbing while in transit.
    When I had this exhaust on my old Mk6 GTI I had a few little concerns (resonator sat very low and a 2 bolt flange right under the rear suspension arms was unsightly) but thankfully on the Mk7 they have fixed these. Fitment is good, no issues, no rubbing. All the pipework sits nice and close to the chassis.
    The exhaust looks great, and although probably one of the quietest aftermarket exhaust options for the GTI, has a nice subtle deep tone to it while cruising, but opens up on full throttle to reveal a great sound.
    Once the mufflers have "burnt in" over a few weeks ill do a short video of how it sounds.
    2017 Ford Fiesta ST
  5. #55
    brisbane
    looks the goods anyway, a bit more aggressive from the rear now...
  6. #56
    Jun 2018
    Newcastle NSW
    Love it. How’d it fit up to the DP?
    Any issues/ time to fit?
    Did you end up getting it through JT mods?
    I was going to pull the trigger on this or some springs this week but some other priorities have taken the dollars away.
  7. #57
    Quote Originally Posted by guile View Post
    Yes the original exhaust tips were a joke. So puny. Looks much better now. Has a nice deep tone to it but probably only 20% louder than stock which is what I wanted.
    Quote Originally Posted by djparko View Post
    Yep fitted up fine to the IE downpipe. I will at some stage get that small section where the pipe reduces to 2.5" removed and a 3" piece welded in though (i did this on my Mk6 GTI a few years back and it looks much neater plus added bonus of no leaks and remove some of the ugly pipe clamps etc).
    No issues with fitment. It fitted up fine. Only thing I did was put about 3mm of washers on the rear exhaust hangers to space the exhaust down away from the rear subframe/suspension arms because it was very close and I thought it might rub. Because the exhaust comes in 3 pieces it actually makes it quite easy to install yourself. I installed the rear muffler first, then the bend pipe with the mid muffler, then the straight pipe up to the downpipe last. Took a couple of hours on the garage floor at night (would definitely be easier with some daylight).
    And yes sourced through JTMods. If you put the item in your cart and fill in your details but then back out of the order, they send you a discount code to use. I paid $1260.
    No rubbing or any issues at this stage - although ive probably only driven about 30km since the install. I'll take it for a decent drive over the weekend.
    2017 Ford Fiesta ST
  8. #58
    I just found this post on A1 Autohaus' facebook page saying they fitted an aftermarket alloy water pump to a Mk7 R. Very interested in this as my original waterpump has recently started to leak and im certainly not interested in replacing it with another plastic OEM pump.
    Does anyone know who makes this pump? If not I will call A1 Autohaus and see if they can tell me.
    My Mk7 GTI PP....turns out I cant resist the VAG.-mk7-water-pump-jpg
    2017 Ford Fiesta ST
  9. #59
    Jun 2011
    Quick google shows all the big names selling alloy replacement water pumps.
  10. #60
    But they are all for the Mk6 GTI. Nothing comes up for the Mk7 (with extensive Googling).
    2017 Ford Fiesta ST
