Try the image tags now.
Anyone figured this problem out?
When you go into "user CP' and edit your signature it seems the image tags are switched off so what should be a picture in our profiles comes up as a link.
Brackie.... maybe you have to switch something on![]()
Or am i doing something wrong![]()
hmmm.. it now says its on but doesnt seem to work.... Must be something else.. ill try and have a look around
And when you get it to work, tell the rest of us how to do it.
I think that I have an idea what is up, will post an idea soon...
So the situation is that it is working as it should.
Go to control panel > signature
Click on the image button, looks like the mountain in a square
then press the preview button and it will appear at the top of the screen
and then it should be live
Cheers, and goodluck - Mick
I think that the only suggestion that I can make is that you are using lowercase letters in the html tags.Originally Posted by worm
ie, [img] instead of [IMG]
only a small thing, but may just be the problem that you are having!
Cheers, Mick
so how do I cut up pics and stick em together in a line so that it can be a signature.
There are 2 main ways.Originally Posted by Golf Loon
1. edit them in a program; or
2. resize them until they are small enough and then put more than one in your signature.
Note that the signature can only be 100 characters long. If you have a problem with a link to an image that is too big, go to www.tinyurl.com and put in the large url and it will return with a small one for you.
for example - http://www.volkswagen.de/vwcms_publi...0002.Image.jpg then becomes http://tinyurl.com/lsacq
And if that is all too much Loon, send me some pics or post them up and then I will make a nice signature for you!Can feel the love?
Hey Loon, send your pics via email to me and ill see if i can join em together... I use MS paint... works fine just takes a bit of p*** farting around
email is
leelengerer at hotmail dot com
