Results 1 to 6 of 6
Thread: images come and go
    Adelaide, South Australia
    images come and go
    can anyone tell me why when i post a pic it is there, and later it is not?
    my images only show on the threads when i am logged into Picasa Web albums (were i got the pics from) if i'm not logged in they do not appear
    got me confused..........
    Jan 2008
    Canning Vale, Perth, WA
    I store all my pics in photobucket and link from there. the only time they dont show here is if I delete the original pic from photobucket
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Dec 2006
    Kilsyth, VIC
    I use photobucket and highly recommend it to everyone.
    http://photobucket.com/
    Add to that the Flock Browser to allow batch uploads and on the flly resizing before uploading (which saves times and bandwidth) and it's the perfect combo.
    http://flock.com/
    Even if you want to keep using Picasa give Flock a look as it supports that too
    http://flock.com/supported-services
    Aug 2007
    Perth WA
    Quote Originally Posted by tapsy View Post
    Could be that your Picasa albums are marked as 'Unlisted' so you only see the pictures when you are logged into Picasa. Sounds like cookies - if you close the browser tab/window with Picasa that might log you out by default then the pics won't show up on the forum or anywhere else you've tried linking them.
    Check the album properties and make sure it/they are Public. Hope that helps...
    '04 BMP MkIV R32 #144
    search getnew
    Quote Originally Posted by geoff_gti View Post
    had a look and pics are public? still not working unless i.m logged on to Picasa
    my have to try photo bucket if i can't sort it out, must be something i'm doing wrong as in some posts pictures are there from Picasa all the time, yet the later pictures i have posted are not (unless logged on??)
    Sep 2006
    Australia?
    There is also the problem that if your work blocks certain sites through there proxy server you will not be able to view it.
