Results 1 to 10 of 11
Thread: Testing the MAF - Boost issues
    Mar 2010
    So i've got a MK5 TDI 2.0L, recently had the turbo replaced (and manifold and actuator, etc, thank god for dealer warranty!), but after playing with Vagcom i've noticed that is quite obviously overboosting.
    I had the Bluefin (superchips) map on it and the 'specified' boost matches the actual on soft acceleration, but full throttle from 1500-4000rpm in 3rd it goes beyond what Vagcom will measure. Ambient pressure was .989bar, boost specified was 2.5bar (this includes ambient) and actual was well above 2.6bar, while this doesn't sound like a big difference, it shouldn't be going beyond what the specified is, I believe...
    What I want to do is test some things, like the MAF to see if anything is going bad and causing this issue. I do notice at idle (it's a manual) occasionally it feels like it may miss a beat. There's no error codes or anything from the ECU and on the stock map (what its on now) it seems to perform OK.
    How do I test the MAF? Are there any other things I should test for? It also has a new EGR!
    I don't know how to attach an excel spreadsheet here, but I can list out the data from a flat out 3rd gear run:
    (Edit - Pasting it in and reformatting wasn't working, so simply take these values in the column and paste them beside each other into excel, will make a lot more sense then....)
    TIME
    STAMP
    7.8
    8.28
    8.77
    9.25
    9.72
    10.21
    10.69
    11.18
    11.68
    12.18
    12.66
    13.14
    13.63
    14.11
    14.61
    15.08
    Group 9 - Field 0
    Engine Speed - (G2
    /min
    1848
    1848
    1995
    2184
    2394
    2625
    2835
    3045
    3276
    3465
    3654
    3801
    3948
    3885
    3675
    3213
    Group 10 - Field 1
    Atmospheric - Pressure
    mbar
    989.4
    Group 10 - Field 2
    Boost Pressure - (actual)
    mbar
    1611.6
    1346.4
    1642.2
    2101.2
    2601
    2601
    2590.8
    2601
    2601
    2560.2
    2478.6
    2407.2
    2335.8
    2264.4
    1713.6
    1397.4
    Group 11 - Field 1
    Boost Pressure - (specified)
    mbar
    1040.4
    2397
    2468.4
    2529.6
    2529.6
    2529.6
    2499
    2468.4
    2448
    2417.4
    2386.8
    2346
    2295
    1071
    1060.8
    1040.4
    Group 11 - Field 3
    Charge Pressure - Control Duty Cycle
    70.9
    74.1
    68.5
    45.4
    25.1
    38.3
    33.1
    28.7
    25.5
    23.9
    22.7
    19.9
    17.5
    44.2
    44.6
    46.6
    Any analysis?
    Thanks,
    Aaron
    Adelaide hills, SA
    When it feels "ok" and there are no fault codes, then most likely - it is "ok"
    The specified and actual don't have to match exactly.
    You can upload the spreadsheet to Google documents and share link in here.
    I have a program that when you enter data MAF, Boost, Engine speed, it tell what it really really should be.
    Just post the link to the spreadsheet and I will check it for you.
    Make sure you log MAF, Boost, Engine speed under right conditions.
    Mar 2010
    Excellent, will try and get it done soon.
    My biggest concern was that I had a turbo go already while running a remap and the actual boost appears to be going quite a way beyond the specified. I didn't think it was supposed to?
    I obviously don't want to replace a turbo . I also read that the turbos aren't the strongest of things on the pd140's...
    Thanks,
    Aaron
    Jan 2008
    Sunshine Coast
    If I had a PD140 I'd be VERY wary of blowing the turbo remapped. The 170 has a lot of changes to handle the extra power, especially the heat involved, and a 140 at similar levels is pushing the reliability envelope in my opinion. I'd be looking at everyway to help it handle the heat, from cold air inlets, wrapped, upping the intercooler ability, watersprays, ducts, etc, even to any way to help the turbo run cooler, increasing the oil cooling it receives, things like that. Even the EGR cooler on the 170 is massive compared to the 140. VW really thought it through.
    There's been more than a few remapped 140'd pop turbo's now, and I've yet to hear of a remapped 170 doing the same, although it's very possible.
    Mar 2010
    OK, I've uploaded it to google docs! I have the 'cut down' spreadsheet here with a few 3rd gear WOT runs and the second link is the 'entire' set of data I collected over a few mins total.
    http://spreadsheets.google.com/ccc?k...thkey=CNCJp4oM
    Looks like as stock the car has boost spikes over 23psi... But even at WOT it seems to be up to 0.2bar above the 'specified', which isn't too much of an issue as stock, but with the remap, I can imagine it being an issue.
    Here's the link with the whole series of data:
    http://spreadsheets.google.com/ccc?k...thkey=CPnvrp4B
    Looks to me like the MAF isn't well as it is reading 435 or so at idle, which according to vagcom should be more like 250???
    Thanks for the help!
    I just had a bit of a look at your logs and it seems on par with some of the MkV TDI's that we've done, they do spike a bit. I'll post up the logs of one of the stock cars on the dyno in a sec. Logged with a Hexcan cable so its bit faster i.e more samples. I spent a bit of time on this one a while ago so we logged everything. Its still running happily as far as I know although the intake flapper thingy did fail at one stage and was replaced under warranty. This is with stock everything
    Log 1
    Log 2
    You might find the superchips map actually has better boost control than the stock one
