hey mate,
i have a 1.9 aaz in my mk3 with a k14, and towing a trailer is pretty difficult because the turbo is so small.... it spools so crazily, that you just have high intake temps and engine warms up too much. ( i also have a big front mount IC).
i'd be looking for something in between the k26 and the k14 - like the k24 or VW spec T3. the t3 and k24 are similarly sized turbo's and will spool much easier than the k26.... k26 just has a big compressor housing, but exhaust side will be same as k24.
as to power, the vw IDI's are famously tuneable, and you wont have any trouble getting soem good numbers out of your audi 5 cyl version. the main thing is just to keep the boost up to it and keep the head on (get some arp or raceware studs). injector pump tweaks do the rest.
look up www.vwdiesel.net for more help in you area![]()
