Hmmm...
Possibly a wire breakage where the wiring passes from the roof cavity into the tailgate. I've seen it a few times.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Ive got a similar problem where the warning light comes on and the reversing light doesn't work. I've removed and replaced the bulb as well as put in a new one. It works for a few minutes (old as well as new globe) then the warning light comes on and the fog light doesn't.
I lifted the centre contact on the bulb holder thinking it was a bit low but it's made no difference. The fault still occurs.
By the way, mine is a Jetta sedan.
Any thoughts as to what is causing it?
cheers...doc
