Erratic Speedo 2013 passat TDI
Gday all, purchased a 2013 passat TDI wagon yesterday, second hand with 65000 on the clock. All went fine for the first 100ks until the Speedo started to be unable to hold position. At cruise on the highway the digital display reads 100kph but the analouge display weaves up and down around 5kph. All other systems appear to work well. Is there anyone who can tell me where the connector for the transmission output speed sensor is or if this is an issue you have seen before. Cheers in advance. Matt
Sent from my SM-G930F using Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
