Results 1 to 5 of 5
Thread: New DPF issues
    Jun 2016
    western australia
    New DPF issues
    hi all,
    over the weekend I installed an aftermarket DPF filter on my 09 Jetta, we plugged the computer in and went for a drive to try and clear the codes off the dash when the old DPF was clogged it was reading 44.5g of soot now we have the new one in first test went 43.2g second:19.5g third:15.2g fourth: 9.8g fifth: 7.6g and then the sixth test went up to 12g and the seventh was 15.5g, now should a new filter take quiet a few KLM of driving to come down or should it be instant? and is it strange that it started to climb? has anyone had experience of new DPF filter that can give me some knowledge? cheers
    Jun 2016
    western australia
    also because I have installed a new DPF shouldn't the dash lights turn off? or do we need to tell the car a new DPF has been installed?
    Dec 2008
    Sydney/Canberra
    You will need to re-adapt the DPF pressure sensor.
    Jan 2008
    Sunshine Coast
    OK, you really need Vagcom to reset the DPF ash levels, the DPF pressure sensor like suggested above, and do any other DPF "adaptations" that are available. If you have a MK6 common rail version the options in Vag Com are far more limited, in MK5 version you have a lot more control. This is not as simple as plugging it in and hoping the car sorts it out.
    Easiest way will be to go to a Euro specialist or VW themselves and have your DPF adapted properly.
    2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside cams | Darkside dump pDPF | Wagner Comp IC | Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Michelin 4s | Golf R subframe | Superpro sway and bushings | 034 engine mounts | MK6 GTI brakes.
    North Beach WA
    Hi gaffatron,
    I'm Steve from WA Euro - Mobile Mechanic Perth - European Specialist
    First thing you need to do is check the engine oil level.
    If it is high, it's a sign that the fuel pump is leaking diesel into the engine oil. this thins the oil and raises the oil level causing too much oil to be blown through and into the exhaust, blocking the DPF.
    If this is the case, it'll need replacement of the fuel pump and an oil and filter change. Then it'll need a forced regeneration of the DPF to reset.
    If you want a permanent solution to DPF issues, i can help with ECU upgrades etc.
    Thanks steve 0449 000 660
    He who dies with the most toys wins!!!!!!!!
    2000 Golf 3.5 Cabrio lowered, low ratio box black-on-black-on-black
    2010 Tiguan TDi Manual Stage2 tune, DPF delete Egr delete
    2008 Jetta BWA DSG Stage 2 tune, 3"VF intake
    Formally known as WA 79 cabby
