Results 1 to 8 of 8
Thread: Pro-vent install on my10 t5 2.0tdi
Shortbus Pro-vent install on my10 t5... 11-10-2011, 06:22 PM
Transporter It is..... :) 11-10-2011, 06:29 PM
Shortbus Thanks mate. What do you... 11-10-2011, 07:50 PM
Greg Roles Clips have a squeeze ring,... 12-10-2011, 06:02 AM
Shortbus Ok, thanks Greg. Now to find... 12-10-2011, 09:14 AM
    Aug 2011
    Perth, WA
    Hi folks, just wanting to check that this is the right hose for my pro-vent. My engine appears a little different than the pictures i've seen so far.
    Adelaide hills, SA
    It is.....
    Aug 2011
    Perth, WA
    Thanks mate. What do you reckon is the best place to put the hoses in? I'm thinking at the initial 90 bends, and how do you undo those clips? I'm a little weary, as this is the first car I've had that has so much bloody plastic on the engine. I am scared of being hamfisted and breaking things if I just try and do it by trial and error.
    Jan 2008
    Sunshine Coast
    Clips have a squeeze ring, just squeeze them on both sides where the grip is. I reused these clips by removing the stock plastic pipe, best done with boiling water to soften it. Getting new cups from anyone but VW is impossible, I've been trying to hunt them down for some time now. Just remember to go from the engine cover, to the Provent inlet, then back out to the intake. Run the drain down below the car with a decent length, and you can get a perfect plastic tap for the end of it from any hardware in the irrigation sprinkler section, cost me a few dollars. Drain every several thou.
    Aug 2011
    Perth, WA
    Ok, thanks Greg. Now to find some hose and get the bracket made up.
    Aug 2011
    Perth, WA
    Documented incase anyone else decides to install one on a T5.2 . Thanks for the help and the good service Greg.
    http://www.vwwatercooled.org.au/foru...ion-64125.html
