Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Performance change after cam belt replacement?
    Dec 2010
    Dalton, New South Wales, Australia
    Hi, my 1.9 TDI Roomster was going very well - bigger intercooler, straight-through rear muffler, custom intake, custom ECU reflash on dyno. (It's the PD engine.)
    Then I got the cambelt changed at 105,000km.
    The performance now seems stronger at the top end but much more sluggish at low/mid revs. The performance at 1500 - 2500 rpm now is back to being like a standard car - on the dyno mine was previously about 20 per cent stronger than standard at these revs.
    After the new cambelt the idle is also now a little rougher and fuel economy seems a little worse.
    Any ideas?
    Adelaide hills, SA
    Re-check the camshaft and crankshaft timing make sure that it was not moved by a tooth and the timing belt is correctly tensioned. If it was done properly performance shouldn't change.
    Erskineville, NSW
    one tooth out?
    Dec 2010
    I didn't do the cam belt change. The company that did it suggests that 'one tooth out' would result in a radical change in performance. Is this true on these engines?
    Jun 2007
    Eastern Suburbs Melbourne
    Aren't PD engines interference engines?
    I know what the other guys are saying, but can't imagine that it'd be running very well (if at all) if it was one tooth out.
    I don't have any evidence to back that up though, and I'm not about to go change my cambelt to find out.
    Did you do it yourself, or at a workshop. Either way, checking the timing would probably be a good idea, as I think scanning the car would be. Might have a sensor that's unplugged, or something that's un related to the cambelt change has gone rye. Just spit balling though.
    i like volkswagens
    Adelaide hills, SA
    one tooth out?
    Never heard of?
    Aug 2009
    Gymea, NSW
    If it is only a very slight change perhaps the old belt was a bit stretched, and now that it has a new belt the tune u had may b a tad bit off. If it is a substantial change it may very well b a tooth out, although usually low end suffers more then high end.
    First thing to do is check cam & crank timing are correct and if they are maybe u need to retune.
    Black 08 GT TDI Manual
    Custom K&N CAI, Custom Catch Can, LED Number Plate Globes, Lowered, Painted Black Gloss Rims & Subwoofers.
    Jun 2006
    Orange NSW
    I'd suggest that maybe the cam timing is a tooth retarded.
    Engines will run 1-2 teeth out usually, as long as there is enough piston to valve clearance.
    Erskineville, NSW
    Quote Originally Posted by Julian Edgar View Post
    I've deliberately done "one tooth out" on other engines in a tightwads attempt to make it go faster (it moved the powerband and didn't really work). I've also managed about 3 or 4 teeth out (because I'm a crap engine mechanic) & the car would still run.
    If they refuse to double check the timing marks then you should be able to check it yourself fairly easily.
    Erskineville, NSW
    Never heard of?
    As in the timing marks aren't lined up / mistimed. Not actually missing a tooth or anything like that.
