Been thinking ahead for an exhaust system, did have my mind set on the uber nice but expensive 2.75" Milltek cat back, but I am all too aware just how little power cat back's usually liberate, and the fact the stock 2.5" is full mandrel. The forthcoming JBS DPF delete pipe is only 2.75" anyhow, and it's the dump pipe area, where the exhaust is hottest, that needs to be the bigger diameter if anywhere. So it's got me to thinking.....
Modify the stock pipe! Given I'll be joining the 103kw crew with a bit of soot action, I figure a downswept pipe is the go. Keep the stock twin outlets, but just have them as dummy pipes for the stock look and to fill the bumper hole. Never have to clean them either!
Been looking around for a suitable muff. Diesels pretty much drone below 500Hz just like gassers, but they do have slightly different needs from what I have read thus far. Been researching Magnaflow and other diesel specific muffs, today I found "aero" mufflers, and they are VERY interesting. Seems if you mount it up close to the downpipe, it actually helps evacuate the system. I'm thinking of putting one of the resonated 2.5" versions right up behind the flexi joint post dump pipe, and deleting the stock resonator prior to the rear axle. Dump the pipe to the ground at rear axle level.
http://www.vwwatercooled.com.au/foru...l_biggif-1.jpg
http://www.vwwatercooled.com.au/foru...muffler1-1.jpg
Despite obviously being a lot nicer, I just can't see a 1/4" bigger Milltek being $1000k plus better, nor liberating a whole lot more power. Hmmmmmmm
The "XL" version is resonated - but it's just a ceramic interior coating, still a straight through muff essentially. 15cm dia x 66cm long though! Lucky there's a ton of space in the floorpan tunnel, thanks to the R32.
http://www.aeroexhaust.com/
http://www.youtube.com/watch?v=iDTTO...eature=related
