Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 111
Thread: Diesel fuel additives for modern diesel.
    May 2011
    Must try this also.
    With modern diesels is this still recommended and if so who stocks it
    Apr 2008
    Sweet. My wife's 07 Jetta is like an Elizabethan chimney atm. But I do like burying people in a cloud of soot
    Jan 2008
    Sunshine Coast
    Big fan of Moreys smoke killer, and Fuel Doctor or similar every ten thou or so.
    Sounds like your Jetta injectors are dirty Ben.
    Co-incidentally I had my baby in for it's 105,000 km service today. I asked the guys to check the DPF reading for me and it came back as ".06L, max being 0.46 ALL OK". I presume that translates to grams somewhere in there. Going back through my log book/chart I see that I first started with "Fuel Doctors" at about 18,000 km using a regular dosage and then at 28,000 km I did my first "shock treatment". At 37,000 km I changed to Moreys DSK but still do a regular "shock treatment" with FD, normally with the fill after a service ( just as a routine so I don't forget). The car still pulls like a train, and as long as don't plant my right foot ALL the time it gives good economy. I am no expert on these DPF's but I think my reading is pretty good, please advise me if I am wrong.
    2012 MK6 GTD CW DSG Seattle's 3M Black Tint, Michelin PS3's.
    Jan 2008
    Sunshine Coast
    The MK6 DPF will last longer then the MK5's, just the nature of common rail vs PD, and the DPF's themselves are evolving. Fuel Doctor will do stuff all to the DPF directly, but by keeping injectors clean keeps soot to a minimum. Moreys will indeed lower the load on the DPF, as well as lube the fuel pump and injectors themselves, which becomes critical in common rail. Cheap insurance of two vital parts.
    Feb 2014
    Central Vic
    Quote Originally Posted by Greg Roles View Post
    So Greg, should I think about starting the programme on my 2012 103TDI Yeti which has done 18K?
    It was in storage for 2 years (surplus stock) and the kms have almost exclusively country driving and has a DTUK CRD2+ box fitted for most of the distance.
    Adelaide hills, SA
    Consider also Penrite DPF Cleaner.
    Where money is not a problem I use BG244J with a fantastic result in my customer's cars and every 3months in all our diesels. While at every fill up the girls are religiously using Liqui Moly diesel additive, that I pour into a small plastic bottles and store them in the rear door pocket.
    Feb 2014
    Central Vic
    Where do you get the Morey's Diesel Smoke Killer....any auto outlet?
    Adelaide hills, SA
    Repco should have it, but you could probably get it cheaper from some other automotive shops. I get mine from Moreys.
