from the BP page
Originally Posted by
BP
Where is BP Ultimate Diesel available?
BP Ultimate Diesel is currently available in approximately 40 sites in Perth and will be rolled out across approximately 60 sites in Brisbane commencing October 2008.
Can I mix ordinary diesel with BP Ultimate Diesel?
There is no problem in mixing regular diesel with BP Ultimate Diesel. However, maximum benefits will be gained through ongoing use of BP Ultimate Diesel.
How does BP Ultimate Diesel work?
BP Ultimate Diesel has outstanding engine cleaning power so it removes the deposits that ordinary diesel can leave behind on engine components and keeps new engines clean. BP Ultimate Diesel has a high cetane number, and improves fuel combustion compared to regular diesel, releasing energy more efficiently to improve the performance of your engine and at the same time helping to reduce exhaust emissions. It also includes special components designed to protect the engine from rust and wear.
Will BP Ultimate Diesel save me money in the long run?
A cleaner engine will run more smoothly, more reliably and more efficiently, which over time should lead to lower running and maintenance costs.
Is BP Ultimate Diesel suitable for every diesel vehicle?
Yes. Any vehicle that currently uses diesel fuel can use BP Ultimate Diesel. BP Ultimate Diesel has been developed to provide benefits for all types of diesel vehicles old and new.
Will BP Ultimate Diesel prolong engine life?
BP Ultimate Diesel has been specially formulated to powerfully clean your engine as you drive. A cleaner engine will run more efficiently and more smoothly and so over an extended period of time you should expect a cleaner engine to last longer compared to a dirty engine.
What’s so special about BP Ultimate Diesel?
BP Ultimate Diesel is an advanced performance fuel. The unique formulation powerfully cleans your engine and burns more smoothly and completely, helping to improve vehicle performance and fuel economy while producing fewer harmful emissions. BP Ultimate Diesel has been developed for use in all diesel vehicle types. Whatever you are driving – old car, new car, family sedan or van – you can enjoy the benefits of using BP Ultimate Diesel.
Does BP Ultimate Diesel have any environmental benefits?
Specially formulated to burn better, BP Ultimate Diesel reduces harmful exhaust emissions including nitrogen oxide (NOx) emissions and hydrocarbon emissions and can also significantly reduce engine noise.
Will motorists notice the difference BP Ultimate Diesel makes straight away?
BP Ultimate Diesel starts working from the first tankful with immediate improvements in many vehicles. However, best results are achieved with ongoing use.
What are the benefits of using BP Ultimate Diesel?
BP Ultimate Diesel has a powerful cleaning additive that cleans your engine as you drive, giving you better combustion which can make an engine quieter and smoother, cut down emissions, and deliver improvements in power, acceleration and fuel economy.
For further information contact:
BP Technical Helpline
1300 139 700
Source http://www.bpfuelexperts.com.au/index.php?menuID=3
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
