Originally Posted by
Gigitt
Here is my Sooty.
Now the thinking is less smoke = more fuel is being burnt which should mean more power... and hence why the Dyno results are debatable with a lower score (75.1 this time vs 80 last time) - but then alot of people saw a lower result this day, but not as bad as last year where cars were down 15-20kW and on the weekend only 5kW with no changes in mods.
Love your work!
If you are seeing less smoke out the back from the intake, you are definately flowing more air for the fuel delivered. I'd agree the power difference is down to dyno's on different days, and I wouldn't expect much overall power gain from a better flowing manifold, but the response should be better, and you can now add more fuel to make more power because of that increased airflow.THAT'S the good news!
I agree the fuel that is there is now reacting more completely with the extra air, and you should have seen some jump in power, but the difference between a soot cloud and a small ne is quite small, so perhaps you were on the cusp of soot free exhaust, and the available "extra fuel" was only small to begin with. I'd have a crack at turning the fuel up if you can do so easily.
Impressive result from a muffler chop, it must have been very restrictive!
