Results 1 to 10 of 10
Thread: Mk3 Tdi oil alarm keeps bleeping
    Oct 2005
    SE Queensland Hinterland
    Hi fellas and fellettes, just wondering if someone can help. I have a 1996 Mk3 Tdi, and the oil alarm and oil light keep coming on after driving up hills, and more recently even on the flats. The oil sender was replaced and it has sort of done it since. The oil is at the correct level and the engine temperature gauge seems to stay at 90 degrees or in the middle. So why is the bleeping thing going off?before the oil sender was replaced I never had this problem and I drive some pretty steep long hills around the Sunny Coast Hinterland with air-con on, etc.
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Jun 2007
    Eastern Suburbs Melbourne
    I believe that the oil buzzer is actually a low pressure warning, rather than level. I'd be very cautious!
    (it used to happen in one of my cars, but that's cause it was actually low on oil, and the pick up must have starved. Needless to say, I rectified the situation pronto!)
    i like volkswagens
    Dec 2009
    Kew, VIC
    Could be engine wear, oil pump problem, sensor/wiring fault etc.
    For peace of mind, get your hot engine oil pressure checked.
    Gosford Central Coast NSW
    what rpms?
    if you have got the engine very hot and then the low pressure warning goes off at idle, thats not unheard of, and you might 'fix' the problem by using a better quality oil.
    if the buzzer is going off at higher than idle rpms then you might need to investigate your oil pump for wear, or your big end bearings or intermediate shaft bearings. could be pretty serious.
    What oil do you use? I would be using a 5-40 synthetic or semi synth.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oct 2005
    Thanks for the advice, It seems to go off after a fair amount of climbing up hill, so the engine is hot. It does it whether I am in high rpm or low, though if I ease of the acceleration when it goes off and drive more sedately it seems to calm down a bit - though not always. I do the same school run every day, and if it is a cool morning and raining I can be pretty confident the alarm won't go off
    Not sure what oil I use, whatever the mechanic puts in there! It is due a service in March so I'll get him to use what you recommend, and ask him to check the oil pump assuming that's an easy job?
    Mk1 Golf Cabriolet
    Probably worth dropping the sump off to check the oil pump pick up for debris.
    Quote Originally Posted by sparkie View Post
    Not and easy job exactly... and takes some specific knowledge. Make sure you are getting good quality oil in it, makes a big difference.
    I have read 10psi hot pressure difference (at idle) between mineral oil and fully synthetic. If your oil is breaking down it will be causing wear issues - you should try to rectify it asap
    '99 A4 Quattro 1.8T
    Oct 2005
    OK thanks for the heads up on getting something done asap. My mechanic suggests that we put an oil pressure guage on the engine and run it hot to see what is happening, in case the new switch is faulty. So does anyone know what pressure the oil should be when the alarm switch triggers the audible alarm and light on the dash? BTW the oil I use is Fuchs 10-40 synthetic
    Mk1 Golf Cabriolet
    Aug 2007
    Yep oil pressure test is what you need to do, so the recommendation is correct there. Also depending in the colour of the switch depends on its function and what pressure it reads, you have blkue, brown, white and black all different.
    I still have a listing of pressures in my "black book" if you need to know what switch is doing what ping me a pm
    cheers
    Jmac
    Alba European
    I think the mk3 diesel have a blue switch and the alarm is normally set to go off at below 8psi
    Hot idle pressure you really dont want much less than that worst case, and it should go up to ~30psi hot at 3000rpm (roughly speaking 10psi per 1000rpm is about right.)
    '99 A4 Quattro 1.8T
