After discussions with Cogdoc and reading though a mountain of posts I have decided to have a hack at installing a Provent on my Jetta. I have not been able to find pictures or instructions for my specific engine so I though I might document my questions/answers and installation here.
I am looking at this kit from Western Filters (thanks Roaming Refuge) as it comes with additional installation hardware:
- 1x provent 200 crankcase unit
- 2x 1mtr lengths of 5/8" silicone oil resistant hose
- 1x 1mtr length of 3/4" silicone oil resistant hose (may not be required for patrol users)
- 1x 1ft lentgth of 1" silicone oil resistant hose
- 2x reducing straight joiners from 1" - 3/4" & 5/8"
- 8x stainless hose clamps.
I also found this how-to that positions the Provent on the oil filter housing. See below:
While this is not my engine (and there is no room next to my oil filter) I started looking towards the front of the engine bay. Is there any reason (size, heat, movement etc) that would prevent me from locating the Provent on the fuel filter housing utalising the void between the fuel filter and the headlamp? See below:
I have been looking at hose routing and thought that I could rout the hoses accross the top of the engine to the top left corner and along the void between the pulley housing (I hope that's what it is) and the coolant expansion bottle to the Provent mounted on the fuel filter housing. I can't see any problem with regards tot he engine cover. My questions are, is there any heat issues with running the EGR line so close the coolant system?
I assume (noob question) that the flow that I am bypassing flows in the direction of the arrow?
I haven't thought about the drain yet.
Anything else I need to be aware of?
Cheers in advance. Pax
