Originally Posted by
kleung
My cigarette lighter socket has solder terminals, so I figured it'd be easier to just solder the wire directly. More than one way to skin a cat I suppose.
They all do, solder 2 wires on. Power goes to the centre one and crimp the correct joiner to it
Not much choice, as the addafuse won't pass current without a fuse installed. Not 100% sure I'd trust cheap Chinese ciggy chargers, TBH. I meant the amps wont matter a 5 or a10 Of course it wont work without one Sheeez
The screw I mentioned attaches to what looks like a part of the frame. It's definitely metal, and I got 12V on my multimeter when I used it as an earth point from the fuse take-off. You should not use voltage readings to find earth. Use resistance and when you have a circuit it should read 0.00 Thats why I used the door hinge as its definitely part of the body and then use the other end to find a circuit.
Never look for an earth off a power point or you could short it
I randomly tested a few of the other spare fuse slots, and none of them gave me any voltage. The addafuse essentially gives me two separate circuits anyway, so if the cig socket circuit fuse blows, my OPS should still work, as it's on a separate fuse.
Only the top contact of the spares have power either all the time or only when the key is on
Make sure you put the addafuse in the correct way with the wire facing down as per the pic in previous posts
