I don't think I can do it .... As I don't know what version I have which is needed to know what to get, also don't have the maps CD/DVD so back to the original question...
Who wants to do it for me.
Printable View
Its pretty straight forward, i wasnt able to get the firmware version off my unit so i ended up pulling the surround off removing the 4 screws that hold it in and reading the model/serial number off the sticker on top of the unit which was real easy.
With a nick name like basic should I trust you lol...
Will go try pull it off now bbs
Ok all done, was basic will give you that I usually snap plastic but all good...
So now can you confirm if I need maps disc or should I be ok
http://www.vwwatercooled.com.au/foru...jaqagy3e-1.jpg
Would be a good idea if you put a location in your sig because there is firmware and maps for Aus and for Europe and should only be put in the correct units.
This is an Australian forum and the 4120 is for here There is a separate one, also 4120 for Europe The Aus maps are about 600mb The European ones are several gig and wont go on an Aussie partitioned unit
Done and done... In Melbourne I should have said that.
I can understand why you would think I ain't from here lol
My English writing skills suck.
So before I go ahead and attempt the update can you confirm I don't need anything else, shouldn't have any issues with Bluetooth and so on.
Thanks
Melbourne/Australia
Thanks for that.
I already have my location set !
Will try fix it when I get home, using tapatalk on my phone that's probably why.
