Suggest you look at vwnavi.com - there's lots of detail on this.
Hi guys,
After doing some basic research, I wanted to know if anyone has succesfully upgraded there MY08/09 climate control to the late MY09/10 Climatronic panel?
Early climate control panel:
Updated Climatronic panel:
Close up:
Obviously the RNS510 is already equipped to display the climate settings on screen, and since the two actual climatronic panels use the same mounting holes behind the bezel, it seems that the actual bezel/fascia is the only difference?
Wonder if it would just work withe a panel swap or if it would require an activation via Vagcom?
D.
Dino.
SQ5 V6TDI | 911TT | Polo 6C
Thanks bud, I will go and have a read!
- Sent from my iPhone using Tapatalk
Dino.
