Results 1 to 10 of 15
Thread: Passat Alltrack Dash Rattle
    I have a very annoying rattle around the instrument cluster and another in behind the chrome trim under the drivers side air vent. When I push on the chrome strip under the air vent it seems to disappear. As for the instrument cluster I have stuffed some business cards in the gap between the plastic instrument cluster and the binnacle, that seems to have worked for that one.
    Any ideas on some real solutions would be great as would a suggestion on how to remove the chrome dash trim.
    Love the car apart from that. Just returned from a 3000k Xmas trip, it just eats up the miles.
    Passat Alltrack sports pack - silver
    Mk7 Golf TDi White - 18" VW "Rotary" Wheels
    Pacific Paradise QLD
    Mine got the rattle under the vent after I went across an awkward driveway Have partially fixed it by stuffing some foam in between the dash front and the black panel above the R/H glovebox under the ign .
    Think it might actually be the tube into the vent has pulled away from something as there was a creak in there when I went over the driveway.
    Aug 2007
    I think that i have the rattle as well. i actually lost a clip from the fuse cover that i have yet to recover when installing premium cluster. will be investigating it at some point when i pull it apart to fine the clip.
    Dec 2012
    Sutherland Shire, Sydney
    I have the same rattle in my Skodat Octavia - sounds like a few washers rattling on a thread (presume the bolt has backed off)
    I have not looked into how to get under the dash to sort this out - it's on my todo list
    Will be interested to hear from anybody that has sorted it out
    Quote Originally Posted by Martin View Post
    Must be a VW group epidemic as my POLO has exactly that in the left rear LOL
    Let me know how you get on. I will be pulling mine apart when the heat backs off
    Sunshine coast
    Anyone had any success in finding some info on how to remove the dash trim around the cluster? I think I have the same issue with my 2013 Wagon.
    132TSI Tiguan Allspace
    Jun 2013
    I did mine a few months ago on a 2012 wagon, just be gentle and pull it towards you. There are some rubber "dampers" that make contact with the actual dash near the mfd. These can potentially fall off so just refit if you do.
    Good luck
    Did you have to leaver it off ?
    Jun 2013
    Quote Originally Posted by Mchap View Post
    No from memory pull very carefully towards you.
    I have up the first time. But charged with confidence I succeeded the second.
