I reckon you should run around in 2nd for a week and clean out the exhaust that way.![]()
I suspect you are right and there's a good amount of soot built up in the exhaust. Lots of cars emit a puff of black when you first open them up, due to the richening of the mixture.
I wouldn't worry about it breaking if you tune it, there's thousands of tuned 2 litres on the planet. There's a lot more tuners out there than APR so do some more research on that subject.
Cleaning out the intake is a pretty time consuming job, a grand seems a bit heavy. There's no other way to do it though.![]()
There is nothing unusual about this at all - however it's more common on tuned cars
I had my ECU flashed at 14,000km and the car has blown this very large cloud of fuel haze ever since
It's more noticeable if you've been quietly driving for some time and then floor it.
I know ~5 people with Octavia's (most are tuned) and they all do it
The stock car does it the least
Just check your exhaust exit, put your finger in and touch the side
If it's dry soot you are fine - if it's wet slime your engine is tired and has some blow by (needs a rebuild)
Direct injection into the combustion chamber means there is no fuel washing over the inlet valves
Hence they can and do get carbon build up for sure
At that mileage, probably a good idea to have it cleaned,
but there are other more cost effect methods
Mountain bike Mike has cleaned the inlet valves himself and Brad explained another technique
Read about it here: MountainBikeMike's Skodaru
As long as the engine is not blowing oil (you could do a compression test) go for it
The APR flash really puts some life into the engine and makes over taking a breeze
APR Stage 1, the top end is worse than stock, Stage 2 is the ducks guts but you need the down pipe also
Absolute nonsense - exhaust restriction does not have any effect on fuel supply!
The fuel is controlled by a closed loop system,
the ECU is watching the O2 sensor and controlling the fuel supply accordingly.
At full throttle a lot of cars go open loop and the ECU gives the fuel directly from a predefined map.
When we go stage 2 we use a different down pipe to get a bit more gas flow, mainly from the hi flow cat
The stock cat is 800 cell - the hi flow cat has 200 cells
This just enables better flow (does not alter the fuel supply)
Our Octavia's have the same 2L TFSI and TSI engines used in the Passat range
The performance down pipe we use is a Jetta upgrade item
Go to Repco and buy a bottle of fuel injector cleaner - Nulon/Repco/LiquiMolly
There is a normal version and a heavy duty version
Fill the tank with fuel - put the correct dosage into the tank
(If using the heavy duty cleaner don't do a lot of hard driving at full throttle)
Once the tank has been consumed you should notice the idle is now smoother
Do this every 4 or 6 months
Hey mate I have a 2008 passat have stage 1 apr, carbonio air filter and thing goes hard for a wagon next step is dump pipe which in process doing. Only issue and worry I have is the gearbox if it can hold that much power as I don't have the dsg.
The manual gearbox is strong enough - no question about that
It's the small DSG clutches that are the weak link, the manual clutch has no issue
(APR Stage 2 is just over the torque capability of the DSG clutch but I'm not having any problems)
I don't have the manual gear box I have the tiptronic but non dsg. You got any pics your ride Martin
Hmmm,
Numerous cars are sold as "Tiptronic" but they are not the real Tiptronic,
They are just a torque converter auto with a little bit of electronic control
I think the Passat "Tiptronic" is actually a ZF auto with torque converter
Here is my humble Octavia
I've done some carbon wrapping of the dash
