Originally Posted by
booba
oh, the camera in the front is for lane assist, traffic sign recognition, high beam assist or sometimes known as front light assist and also for dynamic light assist.
you can turn on high beam assist/front light assist if you have the camera
you cannot turn on dynamic light assist unless you replace your headlights with the following models
gas discharge headlight with dynamic main beam light control (left-hand traffic only) - LEFT 3AC 941 043
gas discharge headlight with dynamic main beam light control (left-hand traffic only) - RIGHT 3AC 941 044
i have attempted to flick the byte for traffic sign recognition however it didn't recognise australian street signs.
Here is the coding for anyone who is interested
Dynamic Light Assist and Front Light Assist - Headlight replacement and Driver Assistance Package required at least for au delivered passat
Controller A5, Byte 2, Check bit 1
Controller A5, Byte 2, UnCheck bit 0
Controller 09, Byte 11, Check bit 3
Controller 29, Byte 29, Check bit 3
Front Light Assist / High Beam Assist
Controller A5, Byte 2, Un Check bit 1
Controller A5, Byte 2, Check bit 0
I won't bother with traffic sign recognition unless i can get it to work.
