Results 1 to 10 of 10
Thread: What aftermarket Roof rack do you use?
    Sydney,NSW
    I want to put a roof rack on my B7 Passat sedan but not sure what. What do you guys recommend. I plan to put a fishing rod and also bike.
    I put whispbars on mine as I don't take them off much. They don't make much wind noise and the rubber strip stays in the accessory channel unlike the Thule ones that needs to be removed/cut. That said, Thule are good as you don't need tools to get them on/off so would be good if you weren't going to leave them on. C
    Sydney,NSW
    Quote Originally Posted by Wigspotter View Post
    Do you have pics pls?
    May 2007
    This should help; Find My Car
    Sydney,NSW
    Thanks
    Jul 2007
    Brissy
    With whispbar the hex tool clips onto the cover so its always there when you need it. They are a lot quiter than the Rhino aero bars too.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sydney,NSW
    Found one on eBay for $300 with free shipping its a S6 100cm
    Is that the right one for our car?
    Dec 2012
    Sutherland Shire, Sydney
    This is the one I got - looks good and is silent
    Prorack Whispbar S44
    Jun 2013
    Does the whispbar allow your to slide on thule attachments using their square bolt locking system used on the proride and roof boxes ?
    I'm pretty sure it's a universal channel. I have a Thule bike carrier on mine. If it has the same square head bolt then yes.
