Results 1 to 10 of 15
Thread: Seat Belt Chimes
    Sep 2009
    NSW
    Seat Belt Chimes
    I'm new to this thread so thought i could add some value..[controversy more likely]
    Really cannot handle the annoying chimes from the seat belt . So it turns out you can simply UNPLUG the 2 way connector under the seat.
    there is a small tab that you need to push in ( on the right hand side- push left) before you are able to pull out the connector. its tight in there even with the seat raised, you're guaranteed to scrape knuckles.
    Anyway, i KNOW there will be the usual bunch carrying on about this- but don't waste your breath- I DO wear my seat belt, just have a habit of doing it up after ive backed out of my long skinny driveway. And some people will find this helpful.
    Aug 2007
    Adelaide.
    I will... I usually put my bag full of university crap on the passenger seat and sometimes it's ehavy enough to make the car remind me that it's not belted in!
    R36 =
    Same here. Although if you try to make sure that your bag isn't resting on the middle part of the seat it seems to help.
    Or maybe I should just put it's seatbelt on so it feels nice and safe
    2008 Candy White Passat R36 wagon, Satnav/auto tailgate/towbar/sunroof. And now tinted!
    Feb 2008
    Outer East - Melbourne
    You can prolly achieve a cleaner solution with software change... possibly disable the chime while in reverse only?? I'm sure someone here will have an answer....
    BTW perhaps a pic of the forementioned connector and location may assist others
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
    Adelaide hills, SA
    It can be easily disabled in VCDS (Vag-com).
    Feb 2008
    The answer I was expecting....
    May 2009
    Q
    i keep hearing about the VAGcom stuff.
    Is this software available through the heavy rain channels (torrents... hint hint)?
    Is there a special cable to plug in and where is it located?
    USB?
    Maybe there's a thread somewhere that someone can point me to.
    Adelaide hills, SA
    Quote Originally Posted by Luminary View Post
    USB?
    www.ross-tech.com or just google ross-tech and find more options, for me the safest was to buy genuine ross-tech cable and the software from OZ distributor. Others faund that the e-bay cable does the job too.
    Jul 2005
    i thought it only chimed once you were doing over about 20kmh???
    it wont chime in reverse either.....
    legally you are only required to wear your seatbelt over 20kmh and going forwards.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Apr 2009
    Melbourne, VIC
    dumb topic really... where a seatbelt when in a moving car! regardless of speed.
