Results 1 to 7 of 7
Thread: Quirky feature in your B6 Passat
    Dec 2007
    ivanhoe vic
    This will display your speed as a digital readout in the rhs display of your climate control
    For Climatronic, hold together the econ and air out the top buttons (ie the top button on the right with the arrow up). You will then see some odd numbers in the areas where the temperature is normally displayed. Release the buttons.
    Next, turn the left temperature control until a large 19 with a small 0 to the right is visible.
    Now read your actual speed on the right temperature display in kmh.
    Enjoy.
    B6 Passat Wagon No KESSY
    Feb 2008
    Richmond, VIC
    Works for Most models now.
    Its very handy, i have verified (in my car at least) with the overhead speed checker on the geelong freeway, and GPS that it is accurate, at least to those 2 devices.
    quite surprising how far off the dash speedo actually is.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Dec 2007
    ivanhoe vic
    exactly right steve was thinking that driving on the freeway last night.
    Mar 2007
    Country NSW/Southern Tablelands
    speedo/temp
    How do you turn it off? Or does it go back to normal after turning the car off?
    How did you come by this info? And any other little tricks? I can't wait to try it.
    Man In Black (MIB)
    2007 V6 4Motion Passat, Black, Leather, DSG, 18" Wheels, Bi-xenons
    2010 Mk 6 Golf R, 5-dr, Rising Blue, DSG, leather, ACC, RVC
    Dec 2007
    ivanhoe vic
    goes back to normal once you switch ignition off and then back on.
    I like playing with things hehe - no off a US B6 forum.
    www.vwvortex.com
    go to cars sections, then volkswagen then passat b6.
    Aug 2007
    Adelaide.
    In the GTI, I press the econ button and it goes back to normal - tap the up and econ butons again and the speedo is back.
    R36 =
    Feb 2008
    Perth WA
    Quote Originally Posted by Man In Black (MIB) View Post
    According to this thread
    http://forums.vwvortex.com/zerothread?id=3140397
    these features are also available:
    * 1.0 : Temp as read by sensor in middle fan speed knob
    * 1.4 : light intesity falling on same sensor
    * 4.0 : Outside temp - front bumper
    * 4.1 : Outside temp - roof
    * 4.2 : Outside temp - rear bumper (inside temp?)
    * 15.0 : Oil temp
    * 19.0 : Uncorrected speed (Kmh)
    * 19.1 : Uncorrected speed (Mph)
    * 19.2 : Coolant temp
    * 19.3 : Tachometer
    * 19.4 : Presumeably oilpressure
    * 25.0 : Voltage
