Hey guys,
Need some wheel spacers for the Mk1 ASAP!
Just fitted coilovers and my wheels don't fit, I need at least 10mm spacers I think.
Will need to get longer wheel nuts then I guess.
They sell them in autobarn but the centre diameter is too big.
Any help appreciated
Your Cabby bolts should be long enough...I checked and found my Cabby bolts are longer than std. Mk 1 bolts, that I got from a wreck the other day. I've been running the 10mm spacers from Autobarn on the rear with no probs....you just need to centre them, by either sticking them to the back of your rims (yes, a tyre shop did this to one of mine) or just by manually moving the spacer in place with a screwdriver..as you rotate the rim..prob. no good for your front wheels, but I get no wobble(or out of balance) on the rears.
Good luck
Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
