Golf / Passat VR6 ABS Speed Sensor
Hi all,
I've sold my Passat and need to get it sorted for the new buyer. I need a rear wheel ABS Speed Sensor, P/No. 191 927 807D. (P/No is the same for Golf or Passat -up to and including 1995)
I ordered one from VW yesterday and they sent the wrong part Turns out there are none in the country.
I will order one from ECS or GAP if I can't get one locally, but I really want to get it sorted urgently so I can move it on to the buyer (fellow forum member!)
Can anyone help?
Thanks
Dan
0407 559 729
How do you know it's duff? Is it physically broken? Or been snagged by a scanner?
You may be able to clean it. If you look under the back seat you will probably find the plug, you can measure the resistance of the sensors with a multimeter. Compare them all. About 1 K ohms IIRC.
Thanks Gavin,
Will do. It was scanned as faulty. I have my fingers crossed that the scan is correct although I know these units are fickle.
- You may not post replies
- You may not edit your posts
Forum Rules
