I can do the leaf cover for you Gavin, ther digital idle stabiliser ( DIS ) is available from VWclassic parts, you can also use the same unit from a watercooled caravelle.
Gear selector rod is same as the 4 speed one from memory, I will check etka and confirm that for you.
Prob got a 6 stud exhaust manifold also, you want a std one or the GTI version ( larger holes, larger studs and wider spacing) ?
For a better mod you can use a MK3 exhaust manifold and the TT downpipe that is made for this conversion, I have one on Val's cabrio and it all the ducks nuts..
Lots of MK 1 Scirocco's...
Cheers,
Grant...
