Page 19 of 19 FirstFirst ... 9171819
Results 181 to 186 of 186
Thread: Arteon VCDS / OBDEleven Tweaks - Confirmed working
  1. #181
    Feb 2014
    My wife's MY22 Tiguan has a little average fuel consumption arrow on the digital tachometer (see below).. is it possible to enable that in a MY18 Arteon?
    Arteon VCDS / OBDEleven Tweaks - Confirmed working-20221109_080547-jpg
  2. #182
    Apr 2023
    Gold coast Australia
    Quote Originally Posted by DAS AUTO View Post
    Audi Mod
    Love the difference it makes...I thought initially it was not such a dramatic improvement until reverted back to standard values for a few days. So worth the small outlay for the ODBEleven
    Get on board!
    Was that the change to audi, if so can you share how you did it in obdeleven
    Thanks
  3. #183
    Apr 2023
    Can you tell me how to do the audi setting I don't really understand how to change long coding as I don't understand the layout. Ie is the top line the byte but then under it it says byte ect
  4. #184
    Apr 2023
    Coding
    Quote Originally Posted by david86 View Post
    Had just activated traffic sign recognition... doesn't work as well as expected in Melbourne metro I.e. road sign detection only mode ignores map data so it holds the 80kmph when turning to a 50kmph side street. Is there any way around to get the system to fall back on map data?
    Do you remember the coding trying to do it on my22 with no luck.
  5. #185
    Mar 2019
    Mordialloc, VIC
    Quote Originally Posted by neveo71 View Post
    No sorry, was so long ago and I deactivated it a few days after posting
  6. #186
    Pacific Paradise QLD
    Top row is BYTES columns are BITS
