Same with drl front light intensity along with Scandinavian rear drl
Printable View
Hmm ok - mine did it no problem. So with VCDS - for the steps I went to:
1. 01-Engine
2. 07-Coding
3. Long Coding
4. Change the drop down option in Bit 0-2 from "01 Manufacturer: Seat/Skoda/Volkswagen" to "02 Manufacturer: Audi"
That was it.
Have you got a link to where you got the info for the DRL brightness tweak?
Hi this should point you in the right direction, with luckhttp://www.vwwatercooled.com.au/foru...2368fadf-1.jpg
Sent from my SM-T819Y using Tapatalk
Ok i had look unfortunately obd2 only drill down to this level and don't have any lables so any help would be greatly appreciated.http://www.vwwatercooled.com.au/foru...51179b0b-1.jpg
Ok I think this is what you need....
Here is my original Long Code - note the first bit 09
Attachment 33642
On the VCDS, I just use the pull down option to change the manufacturer to Audi. This changes the first bit from 09 -> 0A like so.
Attachment 33643
So if you can make that change - that's your setting.
