A tune will generally void the warranty on your powertrain (engine, transmission, differential, etc), but you'll keep warranty for anything unrelated (sensors, trim, electrical, etc).
Edit: tuners also warn that even if you revert back to stock there might be a 'fingerprint' left that VW can see it has been previously tuned.
You'd be fairly unlucky for something major to happen in the first 5 years, but it generally relates to the most expensive bits to fix.
I picked up a fully-optioned MY18 today with 30K Kms ($55K). Decided that the MY19 warranty didn't matter so much if I'm going to tune it anyway.
Now the fun begins!
Congrats mate! I'm two months ahead of you and I still buzz getting behind the wheel. Every time. What colour did you get?
Chuck a Stage 1 in there asap and you'll quickly forget all about the R36...
Mine is black - first preference was manganese grey, with black a close second.
I'll order an OBDeleven and discuss options with some tuning shops after Easter. The only turbo I've ever owned before this was a diesel 125TDI, so I'm new to (but familiar with) intake/exhaust and tuning mods - the R600 intake looks interesting and for pipes etc, I'm a sucker for real carbon fiber (have made things with it before)
I was also reading the manual last night (yeah I do that), and it mentioned ventilated seats. I got all excited and rushed to the garage to see, but (as I had thought) just heated seats. I think I saw something about ventilated seats in the USA, so maybe these can be ordered and retrofitted (if not too pricey) - I yearn for ventilated seats each QLD summer.
The MY22 Tiguan Allspace R-Line we've ordered also has ventilated seats with memory (driver and passenger). I get the feeling it'll be a relatively common feature on the latest R-Line and upcoming R spec cars.
Also, it looks like they fixed the wireless phone charger space issue in the MY22 (my phone doesn't fit - same age as the car). Might be able to retrofit one later down the track too. I think this may be the part number for it: 3G0980611
Currently looking into some performance mods to the ECU/DSG, airflow and handling for my Arteon - probably start with a stage 1 package first.
It also seems to have a minor suspension rattle occasionally on some bumps, so some performance lower control arm replacements may an option (if the bushes are worn), some sway bars may also help.
It certainly doesn't handle like an R36, but with some mods it should come up nice. Much more comfortable to drive. Less thought seems to have gone into the little things tho - but I've found that issue with all new cars I've driven over the past few years.
OBDEleven arrived just this afternoon too, so time to learn how to do some long coding. I know how to code, so hopefully switching some bit-encoded settings shouldn't be too scary. Though engineering is 90% about just knowing which screw(s) to turn ... and which ones to leave alone.
Will also look into putting some sound deadening behind the door cards and the boot etc to eliminate some rattles with moderate bass/volume. Did this in the R36 and it makes a big difference - that Dynaudio system sounds better IMO (but I also added a Dynaudio Esotar 1200 sub which is amazing).
Anyhow, plenty of ideas to keep busy with over the coming months (probably years).
Daily Drive: 2017 VW Arteon 206TSI, White, Fully optioned inc Sun Roof. APR Stage 1 + DSG, Gtechniq 10h Ceramic Coating, Ceramic Tint, Ceramic Front/Rear Brakes, Eibach Lowered Springs.
Weekend Drive: 2016 Golf GTI 40 Years (Clubsport) Tornado Red, DSG, Tint, Black Badges
Thanks, I'll check them out. I've been talking to Harding Performance at Coorparoo, they're local, and have a lot of products/info on their website too.
Looks like you've done a bit of work on your Arteon? What kind of upgrades do you think provide the best improvements?
I'm currently looking at starting with a standatd stage 1 ECU + DSG tune, with R600 intake (plus turbo elbow, intake pipes etc) - it comes as a package. Then probably some new lower control arms and sway bars, possibly some other body tensioning. Would lower it, but it barely gets out of the driveway as is (strange, because it's an inch higher than the R36, tho sticks out further).
