PM sent for the camshaft and electronic ignition.
Paul
Hey guys,
Time to put the B1 Passat to rest. Plagued by rust has put an end to the track car project. Amongst other projects and things.
Momo Boss kit. Does not have the horn button. As is. Fits mk1 Golf, Porsche 924 and B1 Passat.
$50 + postage.
Techtonics 260 camshaft. Great entry camshaft that can be dropped into a hydraulic lifter 8v without having to upgrade the valve springs or convert to dual valve springs for the 2.0L 8v. Has had about 500km of use. Yep, bugger all. More info about lift, duration can be found on TT tunings website.
$120 + postage
Mallory Promaster coil. Comes with ballast resistor and attachment plate. Oil filled, Max Voltage 55,000V. 500km of use.
$80 + postage
Powerspark electronic ignition conversion kit for mk1 golf/B1 passat. Great bit of kit. Do away with the points and condenser. No more adjustments. Easy to install. Red wire to the positive of coil and black to the negative. Ill throw in a newish rotor button too.
$30 posted.
dbilas manifold to suit golf 2.0L 8v engines. 2E and ADY. I had this set up to use twin webers. It is also designed to use in conjunction with individual throttle bodies. I have had the injector holes plugged up with alloy dowels and then professionally surfaced welded. If I had the need to remove the dowels its as easy as grinding the welds of at the top and tapping the dowels out. This is a beautiful manifold. It pains me to sell it.
$380 + postage.
Malpassi Fuel pressure regulator and filter. Nice little unit for carburettor setup Filters and regulators the pressure in one. Adjustment range is 1.5 - 8psi. Had about 500km of use. Filters readily available.
$60 + postage.
Jaeger gauge pod. This pod holds 3 52mm gauges. Can be mounded anywhere, upside down etc. Oldskool look. Hardly used.
$30 + postage
Eric
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
Paul
Have sent a PM for the gauge pod. Ta
