Results 1 to 1 of 1
Thread: Second battery plate for T5-T6
    Adelaide hills, SA
    If youíre installing additional battery in your T5, you need a secure battery plate. This one is from my T5 4mo and Iíve modified it to fit 75Ah or 100Ah battery, it had to be lowered otherwise the seat bench would hit the battery terminals on top.
    Itís bolted under the passenger bench seat. The plate can be used to fit std DIN65 battery as well. No need to drill any hole since itís using the seat base bolts.
    Asking $20 pick up only
    Sent from my iPhone using Tapatalk Pro
    Performance Tunes $660 Only till the end of summer
    Wrecking RS OCTAVIA 2 147TSI - DSG 6 sp $1000Link
