does the RNS510 have sat nav and bluetooth options...?
Might be a good upgrade for Kirsts CC as its short the Nav part
I'm considering replacing my RNS510 with the RCD330+ or similar for CarPlay support but am wondering if anyone still wants an RNS 510 and/or what they are worth in today's market?
I've also got an RCD310 (actually two, but I only have the code for one of them at the moment), both were the factory delivery radios in my cars, both replaced as soon as I took delivery.
I also have a Pioneer AVIC F20BT, full NAV headunit with Bluetooth, RVC and USB support. This one was replaced a couple of years ago with a new unit, but it in good condition. I also have a brand new RVC and microphone for this set (which came with the new Pioneer unit, I just keep the old ones installed).
Is anyone interested in any of these units? Make me an offer.
RNS510 only brings the Nav, Bluetooth is provided by the 9w7 module separately.
The RNS510 can be a direct drop in, coding allows the RNS to display stuff on the MFD, I don't actually believe it's actually needed and the RNS just works. Adding an RVC does need coding and is something I would seriously consider doing at the same time, mostly because it's nifty and you can.
Given I retro fit this unit, I have the antenna to go with it.
I've got a Bluetooth module lying around if anyone wants (but no cable with it ). Does the RNS510 require a highline MFD ?
Hawk, do you have a price in mind for the unit?
Hi Hawk,
I assume that the RNS510 has disappeared by now, but just in case (as my 2009 Tiguan one just died)
Regards
Mark
