Results 1 to 10 of 10
Thread: Magnetic sump plugs.
    Adelaide hills, SA
    Magnetic sump plugs M14x1.5
    This is the VW OEM plug fitted with rare earth magnet (not cheap). I can send it anywhere in OZ for $28 with 2 extra Cu washers. The length of the magnet is 32mm from the end of the drain plug. I can make it shorter, if required. The magnet dia. is 8mm.
    The magnets I selected are strongest, the longest magnets that could be fitted to the sump plug and I went for performance rather than price.
    I have plenty in stock and can supply for different car makes as well.
    Jan 2007
    South Australia
    What are the benefits ?
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Adelaide hills, SA
    Less oxidation as the ferrous debris are picked up by magnet and removed from the engine (you have to clean the magnet before re-installing the sump plug), the useful life of the oil filter is extended. Other advantage is that you can inspect the debris when you change the engine oil
    Jul 2009
    Geelong, Victoria
    bump for great product, PM sent for purchase, cheers
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jan 2011
    Will this fit in all makes? I have an MK5 GT Sport.
    MY09 Golf GT TSI
    Adelaide hills, SA
    Most and it will fit MK5 GT. I can also supply magnetic sump plug to almost any make.
    Adelaide hills, SA
    More sump plug magnets in the stock now. The first badge was sold out very quickly.
    Sep 2010
    Heathcote,nsw
    Any of these available?
    Dave.
    103 TDI 7spd DSG
    Porsche Boxster S 3.2L for sunny days.
    Real 4WD Toyota Landcruiser HZJ105
    Will this fit mk4 gti?
    Sent from my GT-I9505 using Tapatalk
    Feb 2024
    NSW
    Hi,
    Are these still available? Cheers.
