sorry to be a novice but what is the application of these?
FS Lamborgihini Gallardo Exhaust Flappers
++++++SOLD+++++
NO LONGER AVAILABLE
Hard to come by as you can imagine.
The flap part measures 2.5 inches EXTERNALLY (69.3mm), so internally would be about 2.25" (allowing for pipe thickness).
I can't measure the internal diameter exactly because there is a small section of pipe attached to each end.
The flaps are actuated by vacuum so could be directly substituted for any factory setups by welding in these new pieces - plenty of pipe to play with.
You could jam them open if you don't already have any flappers on your stock exhaust.
Bragging rights supplied free with every purchase
Search you tube for a comparison between R32 Golf's both original and flapper mod done. The flapper keeps the exhaust butterfly shut until the vaccuum opens it, giving the full whack of power and noise.
best of luck with the sale, cause bragging rights are awesome, but aren't these the same as the R32 ones?
MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
No they are bigger diameter, so you can run a larger diameter bypass pipe.
The stock R32 flapper is only about 55mm external...say ~2" internal diameter
Hey im interested in your flappers. will PM you details
Only one left.
ahahah dom you tripper....i'm surprised "Dyldo" wasn't more interested in them.
78 2-door 1.8 KR 16v - twin dellorto's
Last one still available.
PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
