FS: Simmons OM 17"
This is more an EOI into them being rebuilt as i need to minimise some projects for my mk3.
I have some 17" 5x100 Simmons OM parts laying around ready for bigger lips
each centre is individually stamped with its build number
Mine are silver, but this will give you some idea
will get pictures of centre condition once I dig them out
needs spacer to clear 288mm (8mm id guess) no worries on 232mm rears. havent tried other sizes yet
I can build them to:
7.5et40 (approx 1-1.5" lip)
8et34
8.5et28
9et22 (approx 2.5-3" lip)
and so on
Bolts will be polished. stock nuts re-used
Barrels factory finish.
centre as factory, some marks
fresh lips using genuine Simmons tooling, polished
black centre caps with gold text
torqued and sealed
$2000 firm. built to any of the sizes above. will require $500 deposit and will be a 6 week build time (takes approx 4 weeks to order new lips)
pickup from ferntree gully VIC
or post at buyers expense.
can build to other sizes (example: 8.5et40, 9et34 or 9.5et2
using new barrels at extra cost
can powdercoat lips, barrels, centres at extra cost
can build to 18" at extra cost
- You may not post replies
- You may not edit your posts
Forum Rules
