Pm sent
Mk3 1.8t swap
I’m wanting to sell my 1.8t mk3 swap in the new year, currently still in the car being used as a daily, therefore can take for passenger rides etc if interested.
Included is everything you will need to 1.8t-6 speed swap your mk3.
Audi S3 AMK 1.8t - ‘strong rod’ factory K04 engine (unverified kilometres) at least 11,273km that I’ve put in it over the last year.
Mk5 6 speed fwd gearbox (km’s same as above - no crunching etc)
Stance dubs ME7.5 swap loom (can put any ME7.5 motor in, 1.8t, R32 etc)
Custom engine mounts
Driveshafts to suit narrow track control arms with VR6 hubs
Drive by wire pedal bolt in adapter
Modifications to the engine include
Forge charge pipe
Front mount intercooler
‘Chinafold’ high flow exhaust manifold - ceramic coated and ported
3” Trackslag MK3 swap downpipe
3” stainless steel exhaust
80mm intake
Cold side DV relocation kit - with Turbosmart Kompact BOV
Phenolic intake manifold spacer
Bosch 550cc injectors
ECSTuning stage 1 lightweight flywheel + clutch kit
ECSTuning lightweight pulleys (no a/c)
Intergrated Engineering catch can kit (block + valve cover AN fittings)
Everything included to 1.8t swap your Mk3. Engine, ECU, plug and play harness, gearbox, exhaust, intercooler, intake etc.
$3000 including full exhaust
$2500 for downpipe only
Located Newcastle NSW
Pm sent
this is sad... but GLWS
