I replied to you on WP
Took the VW Tiguan on a dirt track, light off-roading.
Now I can rear a vibration noise in any gear, between 2000-2500 rpm (even in neutral). Above/below this rpm range it's fine. It started right after the car was bumped around. Not heavily, it's an SUV after all.
I can hear it in the cockpit with doors closed, but not outside or with the doors open.
There is no jolts or vibrating feeling, it's just a noise.
Sounds like a bee buzzing madly.
Any ideas what it could be or help me diagnosis?
VW Tiguan 2018 162TSI Highline
VW Polo 2015 81TSI Comfortline
Thanks
It sounds similar to the (except I can't hear it unless I'm in the car with doors closed)
YouTube
Interesting development. Noise is not there when the engine is cold. Develops when it gets warm/hot. No signs of overheating
2017 Ford Fiesta ST
[*UPDATE*]
I canceled VW to look at it.
Drove the car home, noise was there at the rpm range described.
Got back to the city, had the car engine cleaned.
The I sprayed the undercarriage with my jet sprayer. Found an awful lot pebbles in the plastics under the car. Started smacking the plastics to loosen the stones. Jet sprayed what I could (I didn't have a ramp to crawl under the car).
Sprayed around the radiator to dislodge more leaves. Pushed the noise dampening foam back in. Gave parts of the engine another jet spray.
Result, no more noise during a 30 mins test drive, doing lots of 2000-2500 rpms.
If the noise returns, I'll have another look (also planning to get some ramps to lift the car).
I’ve heard about rocks in your head, but rocks in your plastic bits!!!
Ha ha, great to see you got to the bottom of it.
Nothing more annoying than noises in the car
2018 Allspace 162TSI R Line
