Page 63 of 67 FirstFirst ... 13536162636465 ... LastLast
Results 621 to 630 of 667
Thread: Traffic Jam Assist
  1. #621
    Jun 2019
    Paris
    Thx for your answer
    My camera comes from a tiguan of 2019. It had the TJA functional but on my car it does not work ...
    why do you need VCDS or OBD11?
  2. #622
    Nov 2017
    NL
    Quote Originally Posted by Greg607 View Post
    Thx for your answer
    You sure it had TJA functional? If so, then you need to change your ACC sensor for a facelift version.
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  3. #623
    Radar has component protection so just be aware that will need to be addressed if you swap it. Fec also need to be restored.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|3D colour cluster|Quad LED tail rings|Climatronics upgrade|Dynaudio retrofit|B7 RLine Flat Steering Wheel|3AA CCM|TPMS Direct|B7 Adaptive Cruise with Front Assist|Discover Media retrofit|PLA 2.0|Lane Assist|BCM retrofit|High Beam Assist
  4. #624
    Jun 2019
    Paris
    Question Maybe ..
    Quote Originally Posted by Rainesh View Post
    Thx
    Yes I think
    How know if my ACC radar is compatible for TJA ?
    You tell is necessary have vcds for coding the option after upload the parameters with VCP.. Maybe it's just necessary activate an option in my car with OBD11/VCDS for my new camera, do you think is possible ? and if yes which one ?
    my ACC sensor :
    5Q0907572G
    hardware : H10
    software : 0571
    My brother has the TJA on his GOLF 7, his ACC sensor is :
    5Q0907572H
    hardware : H10
    software : 0620
  5. #625
    Jun 2019
    Paris
    Thx for your answer
    Is it possible with a VCP ?
  6. #626
    Nov 2017
    NL
    Thx
    Yes I think
    my ACC sensor :
    5Q0907572G
    hardware : H10
    software : 0571
    5Q0907572H
    hardware : H10
    software : 0620
    First reparametrise the camera with vcp and then do the coding with obd11/vcp or vcds. What you prefer.
    It seems that your acc radar is correct.
    Try the parametrisation
  7. #627
    Jun 2019
    Paris
    thank you
    yes I will see with the VCP
    what is the coding to do with OBD11 after the vcp?
  8. #628
    Jul 2019
    RS - Brasil
    Hello guys.
    I have a Tiguan 2019, with ACC, camera, etc.
    I have VCP and VCDS.
    To activate TJA, just upload TJA parameters through VCP, and then follow the steps below with VCDS?
    A5 > Coding > Byte 16 > set Bit 2-3 to "08" (EA_Variant2)
    03 > Coding > Byte 29 > enable Bit 5
    13 > Coding > Byte 04 > enable Bit 2
    09 > Login: 31347 > Adaption > Channel "Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz" > set to "active"
    To upload the parameters, just use the Upload function and select the TJA file?
    When you perform the procedure, will all settings in module A5 be maintained or reset?
  9. #629
    You need to use guided functions and choose parameter upload.
    It will not overwrite coding or adaptations.
  10. #630
    Jul 2019
    RS - Brasil
    Okay, perfect.
    I'll try and put the result here.
    Thanks!
