Page 14 of 69 FirstFirst ... 412131415162464 ... LastLast
Results 131 to 140 of 681
Thread: Traffic Jam Assist
  1. #131
    Apr 2017
    Nice, Hugo, when do you think you will get your OBDeleven?
  2. #132
    Aug 2017
    Netherlands
    Quote Originally Posted by Hugo_nz View Post
    Did a quick vid this morning of lane guidance working below 60km/h:
    But you had it already activated on buying the car? Or did you activate it in a later stage through VCDS? Or did you only activated ALG and then TJA was also working?
  3. #133
    Nov 2016
    canberra
    Quote Originally Posted by GeeMoney View Post
    I think Hugo couldn't get OBD eleven on-time before the software update by dealer. Once Hugo provides the scan peanut or Golf_nz might be able to find out the bits that are different to help all of us Traffic Jam Assist
    Sent from my HTC One M9 using Tapatalk
  4. #134
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by gorey View Post
    Sigh I don't know. Feels like it should have been here already.
  5. #135
    Jul 2017
    Auckland, NZ
    Tracking my parcel has revealed that my OBDeleven has arrived in NZ I also noticed yesterday that my car has "learned" that I drive slightly to the left side of the lane, and now keeps me thereabouts...no longer ping-ponging between the lines.
  6. #136
    Jul 2017
    Auckland, NZ
    Hi folks. How do I do the scan you are all pining after? I messed around with the software a bit tonight. Certainly easer than coding a BMW. Also, I am unable to access coding or adaptions for module A5. I get an error every time, even with the correct access code.
  7. #137
    Aug 2016
    Auckland, NZ
    This will give you a basic backup of the modules in the car which will give the long coding for all the modules although it seems that 09 Central Electronics shows long coding with all zeros for some reason. You can also go in and backup each module individually which gives all the adaptions as well.
    Traffic Jam Assist
    Interesting you can't get into module A5, which access code are you using?
    Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
  8. #138
    Jul 2017
    Auckland, NZ
    Quote Originally Posted by NZ_GolfR View Post
    Traffic Jam Assist
    Will do that this AM. For A5 I am using 20103.
  9. #139
    Jul 2017
    Auckland, NZ
    Hope this is what you are after:
    OBDeleven data log
    Date: 2017-08-17 07:35
    VIN: XXX
    Car: Volkswagen Tiguan
    Year: 2017
    Body type: SUV
    Engine: CZPA 132 kW (180 HP) 1.984 l
    Mileage: 2171 KM
    01 Engine
    System description: 2.0 R4 TFSI
    Software number: 5NA907115D
    Software version: 0003
    Hardware number: 06L907309B
    Hardware version: H31
    ODX name: EV_ECM20TFS0115NA907115D
    ODX version: 001004
    Long coding: 012500322466050B34100000000000000000000000000000
    Trouble codes:
    No trouble codes found
    02 Transmission
    System description: GSG DQ500
    Software number: 0DL300011P
    Software version: 2002
    Hardware number: 0GC927711G
    Hardware version: H06
    ODX name: EV_TCMDQ500021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
    03 Brakes
    System description: ESC
    Software number: 5Q0614517CF
    Software version: 0513
    Hardware number: 5Q0614517AD
    Hardware version: H25
    Serial number: 60547000000212
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 036010
    Long coding: 0AEE939A54202373477F070162C64950C92AC4E2E046927D3842500842AA4200002F641A1B13111435351919323200
    Trouble codes:
    08 Air Conditioning
    System description: AC Automat
    Software number: 5NA907044N
    Software version: 4301
    Hardware number: 5NA907044N
    Hardware version: H35
    Serial number: 00000B00427990
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002023
    Long coding: 0012000420010001110510000010102A
    Trouble codes:
    09 Central Electrics
    System description: BCM MQBAB M+
    Software number: 5Q0937084CF
    Software version: 0236
    Hardware number: 5Q0937084CF
    Hardware version: H34
    Serial number: 02001705401292
    ODX name: EV_BCMMQB
    ODX version: 017001
    Long coding: 000000000000000000000000000000000000000000000000000000000000
    Subsystems:
    System description: 326 RL 161220
    Software version: 0372
    Hardware version: 033
    Serial number: 00000001612140480936
    Long coding: 0E4DDD
    System description: RLHS
    Software version: 0105
    Hardware version: 042
    Serial number: S3Y17M02D28H20M24S43
    Long coding: 00A8DD
    System description: Sensor, DWA
    Software version: 0316
    Hardware version: 005
    Serial number: 000000000ZY1702302H1
    System description: Sirene, DWA
    Software version: 0314
    Serial number: 00000000000068596766
    Trouble codes:
    U112100 - Databus missing message
    Intermittent
    13 Adaptive Cruise Control
    System description: ACCCONTIMQB
    Software number: 2Q0907572J
    Software version: 0156
    Hardware number: 2Q0907572B
    Hardware version: H01
    ODX name: EV_ACCMRRCONTIVW376
    ODX version: 001011
    Long coding: 320047C35CFF8728749C8065304085
    Trouble codes:
    Intermittent
    Intermittent
    15 Airbag
    System description: AirbagVW21
    Software number: 5Q0959655AR
    Software version: 0317
    Hardware number: 5Q0959655AR
    Hardware version: 003
    Serial number: 003TDR2M44P0
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002154
    Long coding: 98CCC0C00C0000005C5400CF008800000065
    Subsystems:
    System description: BeltPretRevFL
    Software version: 1032
    Hardware version: 106
    Serial number: 5NC857705C0044R01464
    Long coding: 80000D
    System description: BeltPretRevFR
    Serial number: 5NC857706C0047R01489
    Long coding: 80000D
    System description: SideSensor_Df
    Software version: 0887
    Hardware version: 001
    Serial number: 35700000000613C81E1I
    Long coding: 2D2D2D
    System description: SideSensor_Pf
    Serial number: 358000000002AA9C122L
    Long coding: 2D2D2D
    System description: SideSensor_Dr
    Software version: 6149
    Hardware version: 000
    Serial number: 3510001B72465B45B493
  10. #140
    Aug 2016
    Auckland, NZ
    Thanks, I am assuming there was more to this as there should have been a lot more modules but might be too much to list on a single post. I can already see some differences in the long coding of some of the modules compared to mine already I see yours isn't an R-Line so it will make it a bit more difficult to compare the differences.
    I'll send you a PM with my email address and you can email me the full list if it is easier.
