Page 24 of 32 FirstFirst ... 142223242526 ... LastLast
Results 231 to 240 of 311
Thread: Tow Bar for the Tiguan
  1. #231
    Sunshine coast
    When those two are plugged in, expect to get some errors in your coding. I haven't had time to resolve mine yet.
    132TSI Tiguan Allspace
  2. #232
    Jul 2020
    australia
    hi are they supposed to be plugged in?
  3. #233
    Sunshine coast
    Yes otherwise the cable at the back isn't connected to any gateway, or so i'm led to believe.
  4. #234
    Jul 2020
    australia
    Thanks, i will check the wiring to make sure it runs to the back, that's good i don't need to run any wires to the front
  5. #235
    Jun 2011
    Quote Originally Posted by iampivot View Post
    Have you connected the towbar gateway link under the steering wheel?
  6. #236
    Sunshine coast
    yes i've connected them. Have some unresolved errors I haven't time to sort out, due to it.
  7. #237
    Jul 2020
    australia
    Finally my towbar turned up, fitted it all today, biggest pain was the bumper securing nuts hidden inside bumper.
    Tow Bar for the Tiguan-screen-shot-2020-12-12-10-38-49-pm-pngTow Bar for the Tiguan-screen-shot-2020-12-12-10-52-14-pm-png
  8. #238
    Jul 2020
    australia
    after a drive i've found the Lane guidance / driver assist unavailable, unplugging the red plug on the trailer box, it becomes available again, anyone idea why this happens?
    P.S if anyone wants the red wiring loom in the above picture you are welcome to it
    Also remember to change 69-Trailer to region to australia - stops LED warning on dash
    Managed to get it working missed a bit of code, this did the trick
    Tow Bar for the Tiguan-screen-shot-2020-12-13-8-10-33-pm-png
    Attached Thumbnails Attached Thumbnails Tow Bar for the Tiguan-screen-shot-2020-12-13-7-15-20-pm-jpg
    Tiguan 2017 R Line
  9. #239
    Oct 2020
    Hobart, Tasmania
    Just had a Best Bars tow bar to my R Line Mk11 Tiguan (Wolfsberg) fitted. The bar fitted easily and all of the electrical connections as well. Found the Can Bus connection by removing the very small glove box on the drivers side. They are hidden behind a larger loom of wires and not easy to find. Used OBD11 to tell the system that a tow bar has been fitted. Problem - now I have a fault with the Drivers Assistance which says that the "Local Data Bus Received Malfunction Value". Fault code no U116B00. Using the OBD 11 Pro it tells me the fault has been cleared but it has not. Another fault appears within Module 13, Adaptive Cruise Control - Control Module incorrectly coded, Fault code No U101400. Again OBD11 clears it but it returns. Yet another fault arises from the Engine module - Data error value received - Fault code No U112300. Does anyone have any idea how to clear these faults using an OBD 11??
  10. #240
    Jul 2020
    australia
    Which wiring loom did fit, also follow the coding i used above, i can send you mine but i am using VCDS, not sure about OBD11, it doesn't sound like the coding is correct? did you plug the canbus connectors together ?
    Tiguan 2017 R Line
