Page 37 of 48 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 479
Thread: Tiguan Exhaust
  1. #361
    Jan 2019
    Quote Originally Posted by Entheos View Post
    Awesome news - really glad to hear that this sorted it. Magnaflow have a few resonators/mufflers - which part number did you get installed?
    I didn't get the part number, sorry. I can see they have 3 different sizes of mufflers with 3in inlet and outlets but I'm not sure what the dimensions of the muffler are.
  2. #362
    Jul 2019
    Normanhurst, NSW
    Quote Originally Posted by Beedub View Post
    No problems - I'll work it out
    2018 VW Tiguan 162 TSI Sportline
    APR Stage 3 ECU tune, TVS Stage 2+ TCU tune, IS38 Rev F turbo, APR intercooler, APR dump pipe, Racingline intake kit & 034 rear swaybar.
    XForce Varex muffler & controller on the way.
  3. #363
    Jan 2019
    It's 4x9 oval offset and 12in long.
    Muffler mechanic said he had it for about 3 years on a shelf and was going to install a hot dog res when he remembered the magnaflow.
    He claimed the hot dog would sit too low whereas the magna fits just right.
    HTH
    Sent from my Pixel 3 using Tapatalk
  4. #364
    Apr 2016
    Sutherland Shire
    Will a Golf R wagon rear exhaust be the same?
  5. #365
    Jan 2019
    Quote Originally Posted by Nealo View Post
    No, it's a split system. Completely different and incompatible.
  6. #366
    Apr 2016
    Sutherland Shire
    Thanks for that, I did some further research last night and came to that conclusion.
  7. #367
    Apr 2016
    Sutherland Shire
    Still haven't got my car but should be picking up an R exhaust Saturday.
    So next question -
    1) R exhaust with stock resonator valves closed
    2) R exhaust with stock resonator valves open
    3) R exhaust with resonator delete valves closed
    4) R exhaust with resonator delete valves open
    5) R exhaust with resonator delete valves switchable
    I'm strongly leaning towards 5.
    Thoughts?
  8. #368
    Sep 2011
    Melbourne, Victoria
    6. R exhaust with 3 inch downpipe valves open
  9. #369
    It really depends how loud you want it.
    The Tiguan has a centre muffler at the rear of the stock DP. The Golf R centre muffler is in the catback section.
    All the aftermarket DPs are designed for Golf so are just straight pipe after the cat. It depends how f you’re going to install a higher flow DP.
    But if you want noise you need to remove both centre mufflers and open the valves. This can be a bit drones especially on cold start so my (personal) preference is to run with valves closed.
    If I’m going to go for a run through the hills I’ll open them manually but other than that I’ll keep them closed.
    Jul 2020
    Whadjuk, Kwoppa Keppa / Fremantle Western Australia
    can anyone confirm is the Allspace has the same rear exhaust setup as the 5seater?
    2018 Tiguan Allspace TDI DAP+S&V
    2010 Mazda RX8 GT
