Active info display also needs discover pro with optical output.
Both require handling of component protection and FEC and also immobiliser adaptation for the cluster.
Map streaming to the active info display requires optical cable from the Discover unit
My advice listen to kamold, if someone can help you with any retrofit here in Au , than he is the only person with retrofit magic stick .When VW dealer say ' No is not possible'' I will still ask again kaomold ! If he cant help you with retrofits than no one else can If you have money and will anything is possible .
Hello, Kamold.
My name is MJ who tunes Volkswagen in Korea.
We've been installing ACC on Volkswagen 2016 Tiguan 2.0TDI since yesterday, but it hasn't been activated until today.
My car is 2.0TDI 4 motion car.
First, there are many difficulties because ABS coding is blocked.
Would it be possible to get some help?
xkwh84@gmail.com
Thank you
Hello. I need your help.
We use Ureasolution as a 2016 Tiguan diesel vehicle.
ACC is not activated yet.
The ABS pump has been replaced and cannot be connected to the engine. If there is a way to get help and there is a cost, I will pay for it.
e-mail. xkwh84@hanmail.com
Am I correct in understanding that the only required hardware to do this is the front bumper camera, side mirrors with embedded cameras and harness for these? There's no additional control module between the cameras and the headunit?
Edit: picture of the parts required. Assume the rear view camera installed already comes with the controle module with the four camera input, so just the wiring and cameras are required.
132TSI Tiguan Allspace
