Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Tiguan ACC retrofit
  1. #21
    Assuming that control module supports it as you said yes needs to be correctly coded and adapted then calibrated.
    Sent from my SM-G960F using Tapatalk
  2. #22
    Quote Originally Posted by jeromeo View Post
    I got a loaner with active display and discovery media (with the 2 buttons) not the pro. Everything was working fine.
    Sent from my SM-G965F using Tapatalk
    Yes there are Delphi mib2.5 units that are not pro, but have optical output
  3. #23
    Quote Originally Posted by ARTEONMJ View Post
    Hello, Kamold.
    My name is MJ who tunes Volkswagen in Korea.
    We've been installing ACC on Volkswagen 2016 Tiguan 2.0TDI since yesterday, but it hasn't been activated until today.
    My car is 2.0TDI 4 motion car.
    First, there are many difficulties because ABS coding is blocked.
    Would it be possible to get some help?
    xkwh84@gmail.com
    Thank you
    Which ecu?
    In Bosch ECU's it's possible to unlock the coding in flash.
    In simos if ACC is not supported in coding it's not possible to unlock.
  4. #24
    Aug 2021
    Bangalore, India
    Hi guys,
    I am new to this forum. I have a Tiguan Allspace MY2019 in India. This is an imported unit made in Mexico. The car comes with Cruise control, Front Assist and Lane assist as standard. It also has the below mentioned Radar & Camera hardware.
    I was wondering if enabling ACC and TJA was possible through VCDS or ODIS to enable it. My dealer said he’s cool if I use the tool at his workshop but he doesn’t know how to do it himself as ACC doesn’t come on VW cars in India.
    Can the pros on this thread shed any light on how I can go about this.
    Address 13: Auto Dist. Reg (J42 Labels:. 2Q0-907-572.clb
    Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
    Component: ACCCONTIMQB H03 0372
    Coding: 320460C358FF8728749C810500408700000000000000000004
    Shop #: WSC 00066 790 00454
    ASAM Dataset: EV_ACCMRRCONTIVW376 003016
    ROD: N/A
    VCID: 43859048CA72A857FA-8016
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_ACCMRRCONTIVW376" ()
    No fault code found.
    Address A5: Frt Sens. Drv. Assist
    Control Module Part Number: 3Q0 980 654 L
    Component and/or Version: MQB_B_MFK H12 0610
    Software Coding: 000307060102040100021344C150A90084000E20000000
    Work Shop Code: WSC 00066
    VCID: 408F9F44DB64B34FE7-8014
    Advanced Identification/FAZIT
    Serial number: 07101912K23645
    Identification: BOJ-050
    Date: 07.10.19
    Manufacturer number: 2120
    Test stand number: 3645
    Flash Status
    Programming Attempts(application): 0/0/0/1/1/1
    Programming Attempts(data): 1
    Successful Attempts(data): 1
    Flash Date: 00.01.01
    Flash Tool Code(data): 00454 790 00066
    Misc.
    Hardware number: 3Q0 980 654 A
    Workshop System Name: R242
    Equipment/PR Code: 00000000000001FDD2A1E0D5
    Dataset Number: V03935311DJ
    Dataset Version: 0001
    ASAM Dataset: EV_FMKBoschMQBB
    ASAM Dataset Revision: 002041
    VCDS Info:
    Labels: 3Q0-980-65X-A5.clb
    ROD: ERROR - EV_FMKBoschMQBB 002041 ()
  5. #25
    No you can't use vcp and or vcds.
    Yes it's possible but no your dealer cannot help.
  6. #26
    Dec 2021
    Hi, I do have a Tiguan 2018 Trendline. I’ve already rang the dealership to setup ACC but heard no. The vehicle comes with CC and speed limiter as well as front and lane assist but not the ACC. appreciate if someone can suggest if/how it can be done (I’m based in Aus)
