Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Tiguan ACC retrofit
    Jun 2013
    Qld
    I know it has been done.
    Not that straight forward, and need to use the big calibration boards down both sides of the car with ODIS to calibrate the cameras.
    Camera module doesn't have CP, it's coding and adaptation.
    Thanks.
    What about active digital display?
    Sent from my SM-G965F using Tapatalk
    Active info display also needs discover pro with optical output.
    Both require handling of component protection and FEC and also immobiliser adaptation for the cluster.
    Jun 2013
    Qld
    I got a loaner with active display and discovery media (with the 2 buttons) not the pro. Everything was working fine.
    Map streaming to the active info display requires optical cable from the Discover unit
    Jun 2013
    Qld
    So I suppose maybe some discovery media got the optical plug.
    As I definitely send map to dashboard who disabled the map in radio...
    Jul 2017
    My advice listen to kamold, if someone can help you with any retrofit here in Au , than he is the only person with retrofit magic stick .When VW dealer say ' No is not possible'' I will still ask again kaomold ! If he cant help you with retrofits than no one else can If you have money and will anything is possible .
    Jan 2021
    korea
    Hello, Kamold.
    My name is MJ who tunes Volkswagen in Korea.
    We've been installing ACC on Volkswagen 2016 Tiguan 2.0TDI since yesterday, but it hasn't been activated until today.
    My car is 2.0TDI 4 motion car.
    First, there are many difficulties because ABS coding is blocked.
    Would it be possible to get some help?
    xkwh84@gmail.com
    Thank you
    Quote Originally Posted by ARTEONMJ View Post
    Hello, Kamold.
    xkwh84@gmail.com
    Thank you
    Suggest sending Kamold a PM
