Hi All, my Tiggy developed an AFS Error a couple of days ago. The troubleshooting I have done indicates that the passenger side LED headlight cluster is the cause. When you start up the car, headlights used to do a movement check with moving up and down and side to side. The passenger headlight does not do that (drivers side does). The main beams are working but the cornering static light does not come on either (drivers side does).
The headlight assembly looks pretty sealed and I believe there is a kit that is required, as to open the areas you have to cut sections out and use the kit to screw a new cover on.
Anyway, just wondering if anyone has had this issue and whether they managed to fix it. Currently I have my car booked into the local Volkswagen dealership to review and fix but not for another week or so. I'm hoping it is a warranty repair otherwise I could be up for about $3k - $5k for a replacement unit.
Any info or help would be appreciated.
