In that case is the seat being manually (electronically) slid beyond a predetermined limit and resetting itself?
Try this- adjust seat 1cm forward from the place the car automatically moves it to upon entry- leave it in that spot, stop the car, get out and lock it, wait 30 seconds, then try again. See if it still moves. If it does, does it now move 1cm backwards, rather than forwards?
Yes Simon has it Mine if I had it back past a certain point didnt move at all and I went to the dealer and they put some markers on it and said to have it sitting in front of the marker otherwise it wouldnt go back They were right and by setting it a bit further forward it worked properly Should also be able to turn it off in the MMI as I could in the Tiguan
