Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 115
Thread: Ride/Handling mods
  1. #31
    Jan 2013
    I was looking through the thread and the options available. I came across a whiteline rear sway bar for the Mk7 R for $290. This is from Sparebox.
    Whiteline BWR25XZ Swaybar 24mm X H/Duty Blade Adjustable | Sparesbox
    This is a 24mm
    There is a 22mm for $260
    Should this fit just like the 034 listed from Autoimstruct ? A lot more economical as an upgrade.
  2. #32
    Quote Originally Posted by jim2fast4u View Post
    This is a 24mm
    Yes that should fit.
    Otherwise get the Superpro bar which comes with end links in the kit. This is the one I bought and had no issues: SuperPro Rear 24mm Adjustable Swaybar & Link Kit Fits Audi VW RC0052RZ-24KIT | Sparesbox
    It's also on 20% off sale at the moment which works out to $313.56 . So not much more than the Whiteline but you get the end links too.
    Nov 2013
    AUS
    Hey Jim2fast4u, I bought mine 29th of June with that same discount.
    I was informed there is a delay on delivery so expect a bit of a wait. Tigger's was delayed also by I think a few weeks?
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
  4. #34
    Jan 2013
    Thanks for the info guys. I saw that one on there and wasn’t 100% sure on fitting kit.
    I will chat with my mechanic as I was also looking at fitting DBA T3 4000s on the front.
    Was there an ETA provided to you veew
  5. #35
    Nov 2016
    MAPLETON Qld
    Quote Originally Posted by veew View Post
    Hey Jim2fast4u, I bought mine 29th of July with that same discount.
    I’ve been waiting for mine since the 23rd of May, but it should be dispatched next week (hopefully).
  6. #36
    Nov 2013
    AUS
    3 weeks from the 3rd of June when I confirmed I was happy to wait. I'll let you know when I have an update.
    Current:
  7. #37
    I ordered my Superpro bar on the 21 May, confirmed I wanted to continue waiting for the order on 27 May and received the sway bar on the 24 June. Not sure if that helps anyone but around a month wait.
    I had some creaks/noises from the rear the other week and have since re-torqued the bolts and haven't heard anything since.
    Oct 2018
    Melbourne, VIC
    Been noticing a few Tig's in the US running MK7 Golf R springs, so decided to do some research into spring rates, specifically vs. Tig Eibach springs:
    MK7 Golf R
    Front = 190 lbs/in
    Rear = 245 lbs/in
    Eibach Pro Kit (Tiguan)
    Front = 205 lbs/in
    Rear = 290 lbs/in
    If anyone out there is looking into some lowering springs, hopefully this will help you.
    I'm already running Eibach's so this info doesn't help me, but it did scratch my curiousity itch.
  9. #39
    Jun 2012
    Dee Why, NSW
    How's the handling now that you've had a few weeks to test it out? Has the sway bar reduced much body roll?
    2017 Tiguan 162TSI Highline/R-Line
    2017 Audi S3
  10. #40
    Quote Originally Posted by Gladbach View Post
    It sits a lot flatter and turn-in is improved.
    Nil down-sides.
